‘63 Dart heater control cables
60jerry
Denver, CO
I’ve been considering moving the heater controls from below the dash up to that blank area above the radio like the ‘64 Darts. Has anyone done this? It appears that the cables will be too short for this move. Any advice or suggestions. It wouldn’t normally matter, but I am thinking about custom air conditioning mounted below the dash and would like to attach it as high as possible. Thanks for any ideas.
Jerry in Denver
I did mine the same way sadly one cable its just a tad to short. Its still sitting on my work bench waiting to get extended.
Mine were already in the dash above the radio when I got the car for the original family. Couldn't figure out why the one cable wasn't connected to the heater door lever! Now I know! As they had an aftermarket A/C unit installed under the center of the dash!
Why not just use 64-66 a body cables? They were longer from the factory or make your own with (if you can find a kit) the carb hand choke cable with the metal spiral housing.
Just my two cents.
Good luck
Joe
