[FOR SALE] ‘70 Duster 360/4spd
Mopar Automobiles For Sale
  1. vntned
    vntned Well-Known Member
    1,398
    1005
    Apr 28, 2012
    Gibsonville NC
    Local Time:
    4:50 PM
    Contact Seller
    Just testing the waters to see if I can sell this Duster. I don’t have to sell it, but I’ve been encouraged to by my wife, and it’d free up time and money for some other projects.
    Short version of the story is, the car sat in a barn from ‘89 until early 2020. I got it shortly after in a trade deal in the spring of 2020.
    The car originally was an F4 Lime Green Metallic, with F8 Ivy Green interior. It was a 318/904 car with a 7.25 open rear. It came with power steering and AC, as well split armrest front bench and an AM radio.
    In the past year I have replaced the entire drivetrain, suspension and brakes.
    I now has a 360, 4spd and an 8.25” SureGrip rear.
    The 360 has around 15k miles on a rebuild. Specs are as follows:
    ‘70 360 block 0.060” over
    Refurbed cast crank turned 10/10
    Refurbed factory rods
    SpeedPro H116CP 0.060” pistons
    Compression measures out at 9.3:1
    340 windage tray
    Bluebrint Engines front balancer
    Brass freeze plugs
    587 “J” heads w/ new valve guides hardened seats
    New stainless 1.88/1.60 valves
    CompCams valve springs and retainers
    Mopar HD rocker arm assembly
    Stock replacement pushrods
    CompCams 268AH-10 cam and lifters
    CompCams double roller timing set
    Edlebrock LD340 intake w/ Chrysler #
    StreetDemon 750 carb
    ‘68-‘70 340 HP exhaust manifolds
    Stock style distributor w/ MSD wires
    Trans is a ‘67 A833 with the 2.66 first gear. Replaced the front bearing when I did the engine. Overall good condition. I had the factory Hurst shifter rebuilt by Brewers as well as sourced all new rods and levers from Brewers as well as a new 360 flywheel and a Ram HDX borg&beck clutch.
    Outback is a 8.25” rear end that was rebuilt maybe 20k miles ago with a new 3.55 ring and pinion and a Mopar SureGrip differential.
    The suspension is nearly all new.
    PST 1.06” torsion bars
    OE XHD rear leafs
    KYB GasAJust shocks all around
    Hellwig 1 1/8” solid front sway bar
    Hellwig adjustable 1” hollow rear bar
    New front struts rod bushings
    All new steering linkage is Moog
    New big ball joint UCAs
    New front control arm bushings all
    Brakes are all new with a front disc brake conversion from PST using the later 11” big bolt pattern stuff. New spindles, rotors, bearings, calipers, pads and hoses. Rear drum brakes have been all rebuilt with new shoes, cylinders and spring kits. Drums were turned. New rear hose as well. New dual pot master cylinder up front with a plumb’d in line lock and adjustable brake proportioning valve.
    Also under the hood is an aluminum 22” radiator with dual electric fans ran through HD relays, backed up by an upgraded high amp capacity alternator. New rad hoses etc.
    New fuel tank and sending unit as well.
    The wheels are Cragar S/S in 15x7 and 15x8. They are drilled 5x4.5 and are NOT unilug! Tires are new Cooper Cobras in 215s and 275s.
    The car is turn key, and I do drive it regularly, (tagged and insured), but it is still a project. The engine is strong, trans is good, rear end is good, brakes are nice and firm and the suspension is responsive. This same drivetrain in my Dart ran 8.60s at 82mph in 1/8th mile. Fun toy as is, or you can keep fixing it up while driving it.
    Asking $10kobo…
    Located in NC 27249
    • Like Like x 4
    • vntned
      1,398
      1005
      Apr 28, 2012
      Gibsonville NC
      Local Time:
      4:50 PM
      More pics…
      • Like Like x 3
      • vntned
        1,398
        1005
        Apr 28, 2012
        Gibsonville NC
        Local Time:
        4:50 PM
        And more…
        • Like Like x 7
        • vntned
          1,398
          1005
          Apr 28, 2012
          Gibsonville NC
          Local Time:
          4:50 PM
          And a few from tonight…
          • Like Like x 7
          • Pauleyc
            Pauleyc Member
            9
            0
            Jul 10, 2016
            Valrico
            Local Time:
            4:50 PM
            I’m a bit confused is it a 360 with the 340 4 barrel decals, or a straight up 340?
          • vntned
            1,398
            1005
            Apr 28, 2012
            Gibsonville NC
            Local Time:
            4:50 PM
            It’s a 360.
          • DusterDilly
            DusterDilly Mopar its a way of life
            139
            17
            Sep 25, 2012
            Minnesota
            Local Time:
            3:50 PM
            Clean title?
          • vntned
            1,398
            1005
            Apr 28, 2012
            Gibsonville NC
            Local Time:
            4:50 PM
            Yes. Clean NC title in my name. Tagged and insured.
            • Thanks! Thanks! x 1
            • H22A4
              H22A4 Does anyone read this?
              2,320
              1218
              Aug 4, 2006
              YVR
              Local Time:
              1:50 PM
              From a mechanical standpoint you’ve done a lot of work on it. From a structural standpoint, can you post some pics of the underside (front and rear sub frames) and trunk floor?
            • vntned
              1,398
              1005
              Apr 28, 2012
              Gibsonville NC
              Local Time:
              4:50 PM
              Trunk floor needs to be replaced. Structure wise, it’s solid and straight. Needs a small patch in the front dropped boards on each side. Not bad at all. I’ll try and get pics today after work.
            • vntned
              1,398
              1005
              Apr 28, 2012
              Gibsonville NC
              Local Time:
              4:50 PM
              Here’s a few underneath pics. Also, you can see the exhaust is all new. It consists of 2.5” head pipes from TTi, then I had my muffler guy do the rest in 2.5”. It is H-pipe and the mufflers are stainless Flowmaster FlowFX in 2.5” as well. I sounds crazy, but collectively the exhaust alone cost $600!!! This hobby ain’t as cheap as it used to be!
              • Like Like x 5
              • jstoner
                jstoner New Member
                2
                1
                Jul 23, 2021
                South Jersey
                Local Time:
                4:50 PM
                What's the longest trip you've taken it on? Could it make a 400+ mile trip up 85/95 to Philly?
              • vntned
                1,398
                1005
                Apr 28, 2012
                Gibsonville NC
                Local Time:
                4:50 PM
                I haven’t driven that long in one stretch. I’d probably be willing to drive it that far, but I would feel comfortable if it broke down in my ability to get it back going.
                Would you consider towing or paying to have it towed?
                • Like Like x 1
                • jstoner
                  jstoner New Member
                  2
                  1
                  Jul 23, 2021
                  South Jersey
                  Local Time:
                  4:50 PM
                  PM sent.
                  • vntned
                    1,398
                    1005
                    Apr 28, 2012
                    Gibsonville NC
                    Local Time:
                    4:50 PM
                    Some problem area, and other pics by request.
                  • vntned
                    1,398
                    1005
                    Apr 28, 2012
                    Gibsonville NC
                    Local Time:
                    4:50 PM
                    More
                  • vntned
                    1,398
                    1005
                    Apr 28, 2012
                    Gibsonville NC
                    Local Time:
                    4:50 PM
                    And more
                  • vntned
                    1,398
                    1005
                    Apr 28, 2012
                    Gibsonville NC
                    Local Time:
                    4:50 PM
                    Still more
                    • Like Like x 3
