Torkmnstr
318 engine
-Performer RPM manifold
-750 Holley mechanical secondaries
-Camshaft
Advertised Duration (Int/Exh): 290/290
Duration @ .050 (Int/Exh): 240/240
Gross Valve Lift (Int/Exh): .520/.520
LSA/ICL: 106/102
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 3300-6600
Includes: Cam & Lifters (#71977-16)
-Forged Pistons
-Heads and manifold port matched
-Heads minor head polishing
-Headers with v-bands
-3" exhaust
-10” Black widow mufflers
46RH OD Transmission
-2200 RPM stall converter
-Over drive button located on end of shifter
Rearend
-Ford 9"
-31 spline axles
-Diamond locker
-3.54 gear ratio
-Disc brakes
-Mini tub
-Leaf spring relocation kit
-New extra heavy duty leaf springs
-New kyb shocks
Front End
-Stock suspension
-Disc brakes
-Manual steering
-New kyb shocks
-New .920 torsion bars
Electronics
-Electronic ignition
-Powermaster 1 wire alternator
Cooling
-Aluminum Radiator
-Electric fan on thermal switch
Fuel System
-New tank and sender
-Mechanical pump
-New Holley 750 double pumper
Wheels and tires
-Billet Specialies
-Fronts 15x3
-Rear 15x10
-195/55/17 Federal’s
-295/55/17 Mickey Thompson’s ET’s
Body
-All stock sheet metal
-GTS hood
-New bumpers
-New Door handles
-Restored grill
-New Hood inserts
Interior
-New carpet
-New Arm rests
-New door pulls
-New window cranks
-New racing seat belts
-Procar lowback sliding and reclining buckets
-Rear seat recovered
Runs great, never gets over 190 2200 rpm at 65 on the freeway. Paint was done by previous owner, really nice but not perfect. I’d say a 5 footer but very very presentable. Fly in and driver her home! Thanks Tom. $26k obo located in 95123
-Camshaft
LSA/ICL: 106/102
-Forged Pistons
-3" exhaust
Rearend
-Ford 9"
-31 spline axles
-Diamond locker
-3.54 gear ratio
-Disc brakes
-Mini tub
-New kyb shocks
Front End
-Stock suspension
-Disc brakes
-Manual steering
-New kyb shocks
Electronics
Cooling
-Aluminum Radiator
Fuel System
-Mechanical pump
Wheels and tires
-Billet Specialies
-Fronts 15x3
-Rear 15x10
Body
-GTS hood
-New bumpers
-New Door handles
-Restored grill
-New Hood inserts
Interior
-New carpet
-New Arm rests
-New door pulls
-New window cranks
