002/003 shackle problem
Suspension, Steering and Chassis
  1. moparmike98
    moparmike98 Well-Known Member
    61
    9
    Aug 25, 2014
    nekoosa wisconsin
    Local Time:
    6:01 PM
    I recently acquired some new 002/003 springs for my 1972 Duster and when I installed them I ran into some shackle problems. When I let the car down the drivers side was borderline but the passenger side inverted into the trunk pan immediately. Tomorrow I plan to jack it back up and loosen everything then ease it back down while using a pry bar on the passenger side shackle to try and flip it. Any other ideas? How come some people need to put spacers between the shackle mount and frame but some don't? They're the same springs after all.
    Car on the ground passenger side (installing new shackle tomorrow)
    Passenger side at full droop
    Driver side
  2. Demonic
    Demonic Well-Known Member
    483
    272
    Mar 21, 2015
    Maryland
    Local Time:
    7:01 PM
    The main leaf is too short or has too much arch. Or, the tolerance in your car's particular frame front to back is a bit long.
  3. 68 Coronet RT
    68 Coronet RT 68 GTS # 508 in Registry
    314
    88
    Nov 5, 2015
    Upstate New York
    Local Time:
    7:01 PM
    I just installed the same springs on my 68 Dart GTS but I put both 002's on mine and I'm glad I read your post as my rear shackles are exactly the same way on both side. I haven't taken it off the jack stands yet as I'm waiting for my new shocks. Holy S$%T now what the hell do I do.
  4. Mopar Tim
    Mopar Tim FABO Gold Member FABO Gold Member
    15,542
    8305
    Nov 29, 2014
    vista CA.
    Local Time:
    4:01 PM
    I am using both 03's The low side......we will see....
  5. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    14,254
    3840
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    7:01 PM
    Had a set on my 69 Dart when I bought it some 12 years ago. The previous owner ran into the same thing. He had to run spacers behind the rear frame mount. I took them off and bought a set of HD springs.
  6. Ddaddy
    Ddaddy I'm changing the World... one pixel at a time! FABO Gold Member
    18,169
    20791
    Nov 7, 2015
    SW of Philly PA
    Local Time:
    7:01 PM
    Have you guys installed the springs backwards? The part that is forward is a different length that the part that is rearward.
    I have them on my ‘69 GTS and they fit like they should. I took this pic just a few minutes ago.
    • Thanks! Thanks! x 1
    • davescuda
      davescuda FABO Gold Member FABO Gold Member
      8,971
      1037
      Apr 30, 2007
      Cheshire, CT
      Local Time:
      6:01 PM
      possible on wrong side
      but I would bolt it up and it will change
    • SGBARRACUDA
      14,254
      3840
      Dec 7, 2006
      PLANT CITY FL.
      Local Time:
      7:01 PM
      I don't think you could install them backwards. The rear end would be mounted way to the rear. If I recall the front spring segment to the center pin is 20".
    • Ddaddy
      18,169
      20791
      Nov 7, 2015
      SW of Philly PA
      Local Time:
      7:01 PM
      I just looked at the OP’s pics. Looks like the passenger side is installed backwards. The length from the main spring to the second leaf is different.
    • Ddaddy
      18,169
      20791
      Nov 7, 2015
      SW of Philly PA
      Local Time:
      7:01 PM
      You can install them backwards,but it should be noticeable in the wheel position in the wheel well. Especially if only one side is backwards.
      • Disagree Disagree x 1
      • 1969383S
        1969383S FABO Gold Member FABO Gold Member
        4,312
        1605
        Jan 8, 2012
        Cumming, GA.
        Local Time:
        7:01 PM
        Is it me or the pic, but the shackle mounts look different.
      • SGBARRACUDA
        14,254
        3840
        Dec 7, 2006
        PLANT CITY FL.
        Local Time:
        7:01 PM
        The leaf spring segment stack is different 002 to 003. the front eye on the leaf spring is way larger than the rear. IF, he had it backwards you would tell it in a second. The front bushing is larger and pressed in. The rear uses two rubber only inserts, one installed front the outside. And they are smaller in size.
      • Ddaddy
        18,169
        20791
        Nov 7, 2015
        SW of Philly PA
        Local Time:
        7:01 PM
        One would think it would be obvious, but it is also possible the manufacturer put the pressed in bushing on the wrong end. Stranger things have happened.
        • Mopar Tim
          15,542
          8305
          Nov 29, 2014
          vista CA.
          Local Time:
          4:01 PM
          lower the jack, then raise it while using a pry bar to force the shackle to the rear/correct location.
          • Agree Agree x 2
          • Ddaddy
            18,169
            20791
            Nov 7, 2015
            SW of Philly PA
            Local Time:
            7:01 PM
            I would also check the front mounts to make sure they aren’t upside down.
          • Mopar Tim
            15,542
            8305
            Nov 29, 2014
            vista CA.
            Local Time:
            4:01 PM
            The front mounts will only bolt one way, the bolts are off set. Unless they have been modified.
          • SGBARRACUDA
            14,254
            3840
            Dec 7, 2006
            PLANT CITY FL.
            Local Time:
            7:01 PM
            I believe the main reason this occurs is the fact that the right side spring has more arch. If you lay them side by side it is obvious.
          • Ddaddy
            18,169
            20791
            Nov 7, 2015
            SW of Philly PA
            Local Time:
            7:01 PM
            Or if they are upside down on the opposite side.
          • Ddaddy
            18,169
            20791
            Nov 7, 2015
            SW of Philly PA
            Local Time:
            7:01 PM
            Post number 3 is using two of the 002 springs so they should be identical from side to side.
            • Agree Agree x 1
            • SGBARRACUDA
              14,254
              3840
              Dec 7, 2006
              PLANT CITY FL.
              Local Time:
              7:01 PM
              He states he hasn't put the weight of the car on the ground yet!
              • Agree Agree x 1
              • Mopar Tim
                15,542
                8305
                Nov 29, 2014
                vista CA.
                Local Time:
                4:01 PM
                The two top bolts are closer together then the lower bolts, the same on both sides. Unable to turn over without enlarging the holes in the mounting location.
              • pozest
                pozest Well-Known Member
                142
                11
                May 1, 2009
                Local Time:
                7:01 PM
                I would use a spacer for sure.
              • SSing
                SSing FABO Gold Member FABO Gold Member
                907
                207
                Feb 24, 2012
                upland, sweden
                Local Time:
                1:01 AM
                I think you have the answer in this pic. The passenger side leaf spring has more arch thus distance between spring eyes appear to be shorter. This only effect the rear segment of course. A spacer at the passenger side rear spring mount is probably what you need. (As some already have said)
                Also important is for the SS-springs to work properly, shackle angel must be forward. Meaning lower spring eye must be rear of the upper mount hole. You may need a spacer on the left side as well. Maybe less thick though.
                It´s a good thing I have a picture to show what I am talking about... right :)
                • krazykuda
                  krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                  47,774
                  12743
                  Aug 20, 2007
                  Orland Park, IL
                  Local Time:
                  6:01 PM
                  @Mopar Tim is correct...
                  I have had this happen to me with installing springs...
                  Jack up the back of the car and let the suspension hang free, then get a pry bar and pull the shackle rearward so it sits properly, then have someone pump the jack to put pressure on the spring while you keep the pry bar on it and pull rearward on the shackle to keep it from going forward. Once you get some pressure on the spring with the shackle pointing in the right direction, it will be fine...
                  No need to loosen anything, just jack up the rear and have jack stands under the frame. Then set the shackle in the proper direction and put pressure on it while prying with the pry bar... (Have a helper pump the jack up while you pull the shackle rearward)...
                  When you put pressure on the spring, it gets longer.... On a new set of springs, sometimes it will go upwards instead of rearward...
                  I encountered this with Espo springs as well and all we did is what I described and it was fine... Once you get pressure on it and get the shackle to go rearward, it will be fine as the weight of the car will keep it in the proper orientation from then on....
                  • Like Like x 1
                  • famous bob
                    famous bob mopar misfit
                    12,736
                    3598
                    Aug 14, 2011
                    okla
                    Local Time:
                    6:01 PM
                    dam guys, they are a lot diff. size !
                    ur rear shackles should be running slightly to the rear/from top to bottom too, "w/ the cars weight on it."
                    • Like Like x 1
