.030" longer push rods and where to find them.
Big Block A body Tech
  1. thesiren74
    thesiren74 Well-Known Member
    1,616
    1217
    Feb 23, 2014
    kenosha,wi
    Local Time:
    3:29 AM
    So it looks like a .050" longer would work but not sure what the plunger travel is for lunati hydraulic lifters. Right now it has SBI 190-1403 Pushrods wich are 9.315 so i seen that Oe pushrods has a 9.375" in the catalog. I'll call them tomorrow.
  2. thesiren74
    1,616
    1217
    Feb 23, 2014
    kenosha,wi
    Local Time:
    3:29 AM
    And another thing i could easily turn the pushrods by hand on the cam case circle so yeah i believe it needs more pre-load.
  3. 72Dart6pack
    72Dart6pack Harder Better Faster Stronger.
    4,353
    4524
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    4:29 AM
    Ask for 2 extra ones. It never hurts to have a spare or two. You won't get that from the speed shops. :)
    • Like Like x 1
    • 72Dart6pack
      4,353
      4524
      Feb 1, 2016
      Roseville Michigan
      Local Time:
      4:29 AM
      I think the spec on the website says they can hold to within .005. The ones they made for me were .003 +/_ to perfect.
      • Like Like x 1
      • thesiren74
        1,616
        1217
        Feb 23, 2014
        kenosha,wi
        Local Time:
        3:29 AM
        Just measured the old pr on a height stand 9.324 wow ..009" difference!
      • thesiren74
        1,616
        1217
        Feb 23, 2014
        kenosha,wi
        Local Time:
        3:29 AM
        Hmm now I'm thinking i should measure the preload maybe too much?
      • thesiren74
        1,616
        1217
        Feb 23, 2014
        kenosha,wi
        Local Time:
        3:29 AM
        Ok preload is right around .120"
      • 72Dart6pack
        4,353
        4524
        Feb 1, 2016
        Roseville Michigan
        Local Time:
        4:29 AM
        That's a lot. But it depends on what the Lifter Manufacturer recommends?
      • thesiren74
        1,616
        1217
        Feb 23, 2014
        kenosha,wi
        Local Time:
        3:29 AM
        Lunati lifters and i can't find the info, it probably has been this way since 2018 and 10,000 miles ago lol
      • 72Dart6pack
        4,353
        4524
        Feb 1, 2016
        Roseville Michigan
        Local Time:
        4:29 AM
        Then just continue to run it..
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        19,131
        6340
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        3:29 AM
        Holy crap, I run .006 - .020 on hydraulic lifters. Kim
        • Like Like x 1
        • thesiren74
          1,616
          1217
          Feb 23, 2014
          kenosha,wi
          Local Time:
          3:29 AM
          Sounds fine when cold then after it gets warmed up it sounds like sewing machine as it kind've did before but not as loud.
        • thesiren74
          1,616
          1217
          Feb 23, 2014
          kenosha,wi
          Local Time:
          3:29 AM
          With non adjustable rockers?
        • thesiren74
          1,616
          1217
          Feb 23, 2014
          kenosha,wi
          Local Time:
          3:29 AM
          I just took it for a ride and runs strong as hell!
        • PRH
          PRH Well-Known Member
          3,172
          4697
          Dec 14, 2018
          So. Burlington, Vt
          Local Time:
          4:29 AM
          I’d say....... most of the time when someone comes up with a different length than what the advertised length is....... is because it’s not being measured the same way.
          Measuring
          • Thanks! Thanks! x 1
          • thesiren74
            1,616
            1217
            Feb 23, 2014
            kenosha,wi
            Local Time:
            3:29 AM
          • Phreakish
            Phreakish Well-Known Member
            1,234
            811
            May 28, 2015
            N. Idaho
            Local Time:
            1:29 AM
            https://static.summitracing.com/global/images/instructions/lun-02002.pdf
            Lunati recommends .020-.060"
            Many hydraulics only have about .180-.200" travel, total. The more a spring is compressed, the higher the stress in the spring. Higher stress = shorter life. The lifters probably collapsed as a result and resulted in the ticking.
            Non adjustable rockers are great for OE, mass-produced applications. Not so great for an aftermarket combination of parts unless everything is thoroughly measured during assembly.
            • Like Like x 1
            • thesiren74
              1,616
              1217
              Feb 23, 2014
              kenosha,wi
              Local Time:
              3:29 AM
              Ugh! Lol im going to get shorter pushrods and see what happens, ran 12.90 and drove non stop for 4hrs straight these things will take beating!
              • Like Like x 1
              • thesiren74
                1,616
                1217
                Feb 23, 2014
                kenosha,wi
                Local Time:
                3:29 AM
                Just ordered 9.250" pushrods and we'll see if i have clearance issues now! Lol
              • 72Dart6pack
                4,353
                4524
                Feb 1, 2016
                Roseville Michigan
                Local Time:
                4:29 AM
                From where? Lol
              • thesiren74
                1,616
                1217
                Feb 23, 2014
                kenosha,wi
                Local Time:
                3:29 AM
                Where you told me to go.
              • 72Dart6pack
                4,353
                4524
                Feb 1, 2016
                Roseville Michigan
                Local Time:
                4:29 AM
                Can we ask the cost? Just be general.
              • thesiren74
                1,616
                1217
                Feb 23, 2014
                kenosha,wi
                Local Time:
                3:29 AM
                Not cheap but $116 , i looked at another set and they wanted $125 from a different place.
                Everything is going up.
              • 72Dart6pack
                4,353
                4524
                Feb 1, 2016
                Roseville Michigan
                Local Time:
                4:29 AM
                Yes I agree prices are getting out of control
              • Krooser
                Krooser Reform School Graduate
                3,040
                2563
                Jul 19, 2015
                Central Wisconsin
                Local Time:
                3:29 AM
                You may have to replace your lifters or at least take them apart to look for damage.
