1.6 verses 1.5 rockers
Big Block A body Tech
  1. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    16,537
    4899
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    6:13 AM
    Is shorter pushrods usually needed? I have 1.5 now and going to 1.6 Thanks. Kim
  2. moparmat2000
    moparmat2000 FABO Gold Member FABO Gold Member
    17,160
    6121
    May 13, 2010
    Grand Tetons
    Local Time:
    6:13 AM
    I could be wrong, but I think the 1.6 ratio is to add to the cam lift. Shorter pushrods kind of negating the 1.6 ratio advantage.
  3. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    39,082
    10634
    Jun 21, 2005
    New York, on a Island
    Local Time:
    7:13 AM
    Not exactly. The shorter pushrod may be needed because of the contact point on the rocker arm. That’s what I think Kim is thinking. You still get the lift extra Benefit.
    • Like Like x 1
    • Thanks! Thanks! x 1
    • oldkimmer
      16,537
      4899
      Nov 11, 2006
      Local Time:
      6:13 AM
      That’s right Rumble. I have new Smith Brothers pushrods that they made too short. I sent them 1 from the motor so they could make an exact match. But that didn’t happen. I have 4-5 threads under the rocker. I only had 2 b4. I have 1.6 rockers to try. If no difference I’ll give Manton a try. Kim
    • AndyF
      AndyF Well-Known Member
      1,793
      1911
      Feb 23, 2009
      Oregon
      Local Time:
      4:13 AM
      There is no universal answer, you have to install the new rockers and make a measurement. If you are staying with the same brand of rocker and they were built at roughly the same time then maybe the pushrods will be the same but I wouldn't bet on it. If you are changing brands then almost guaranteed that you'll need different pushrods.
      • Agree Agree x 1
      • rumblefish360
        39,082
        10634
        Jun 21, 2005
        Local Time:
        7:13 AM
        Kim, if it hasn’t been to long of a time period, I’d. All and complain. Then add in before the ball gets rollling to far to make a new set instead of duplicates at they should have made in the first place. It’s worth a shot.
      • oldkimmer
        16,537
        4899
        Nov 11, 2006
        Local Time:
        6:13 AM
        Andy, they are a different brand. I’m hoping they need a shorter pushrod. I would like to get back to 2 or 3 threads showing. Kim
      • oldkimmer
        16,537
        4899
        Nov 11, 2006
        Local Time:
        6:13 AM
        Rumble, I called them multiple times to no satisfaction. They didn’t help nothing. Didn’t care. This was in July 2017. My race car has sat since then. I’ll never buy from them again or recommend them ever to anyone. Kim
        • xLURKxDOGx
          xLURKxDOGx "An angel fat, at satan's feast" FABO Gold Member
          3,947
          1322
          Dec 27, 2013
          PHX
          Local Time:
          4:13 AM
          That was my experience with them. I told them what I wanted and they gave me a set 1/8 smaller than I told them over the phone and have refused to resolve the issue. Hope you can get them to resolve it Kim.
          J.
        • oldkimmer
          16,537
          4899
          Nov 11, 2006
          Local Time:
          6:13 AM
          I am done with them. Even their shipping was crazy to ship to ND. Kim
        • 70aarcuda
          70aarcuda Master Hoader of SBM FABO Gold Member
          15,736
          4272
          Jan 16, 2005
          las vegas
          Local Time:
          4:13 AM
          I use 1.6 on the intake and 1.5 on the exhaust ...both pushrods are the same length....
          Got at 5 sets of Smith brother pushrods...never had a problem with them....
        • AndyF
          1,793
          1911
          Feb 23, 2009
          Oregon
          Local Time:
          4:13 AM
          Different brand means you'll need to mock it up and verify the length. There is no way to know until you measure it.
        • oldkimmer
          16,537
          4899
          Nov 11, 2006
          Local Time:
          6:13 AM
          That’s what I figured. May need to get another set of pushrods. Kim
        • rumblefish360
          39,082
          10634
          Jun 21, 2005
          Local Time:
          7:13 AM
          Mill the heads! No need for pushrods.....
          :rofl:
          Seriously... good luck to you with this. Keep us updated.
        • oldkimmer
          16,537
          4899
          Nov 11, 2006
          Local Time:
          6:13 AM
          This with the new pushrods. Old pushrods 2 threads showing. I have run the motor some like this. Smith brothers said it’s ok to run this way as their adjusters have more threads on them. They are new adjusters from them. Kim
        • A Body 440 WHY NOT
          A Body 440 WHY NOT Well-Known Member
          199
          62
          Sep 28, 2019
          Jersey
          Local Time:
          4:13 AM
          Mark the top off the valve stems with a sharpie. Install rockers and adj. bar over the engine . loosen rockers. They will leave a ‘clean’ spot where the rollers are hitting the valve stem
          How many threads above the rocker , by the jam nut ?
        • oldkimmer
          16,537
          4899
          Nov 11, 2006
          Local Time:
          6:13 AM
          Threads are flush with jam nut. Kim
          199
          62
          Sep 28, 2019
          Jersey
          Local Time:
          4:13 AM
          Ideal would be a few threads out the top , but if the pattern on the valve stem looks good and you watch the bottom of the rocker so it does not contact the retainer I don’t think you will have a problem
          • Agree Agree x 1
          • oldkimmer
            16,537
            4899
            Nov 11, 2006
            Local Time:
            6:13 AM
            Pattern is pretty good. Lots of clearance. Kim
          • yellow rose
            yellow rose Overnight Sensation
            24,592
            20616
            Jun 19, 2015
            Under The Gun
            Local Time:
            4:13 AM
            There shouldn’t be any more than a thread showing. That’s the most. The actual measurement is the adjuster need to be out .281 minus zero, plus .050 which is right out of the book.
