1/8 throttle miss 198 Duster
Mopar92
Lewisburg tn
So the car starts and runs great cold or hot. The choke works properly. Wide open throttle runs strong. No miss or hesitation. 1/8 or so throttle there's a miss. It doesn't have to be from acceleration. I actually think the accelerator pump is strong. If you stomp it, it accelerates. It's just cruising at a high idle or 1/8 throttle it surges and just doesn't run smooth. All other throttles it's a champ. I am not at all familiar with these little carbs. Here's the carb that's on it.
The canister on the passenger side fender is still all hooked up. Can that thing wreak havoc on partial throttle performance ?
