calrobb2000
Member
hi
is there a 1" bore aluminum master cylinder to use with non power disc / drum brakes ?
thank you !
thank you !
Yea, thats right, higher pressure with a little longer travel.It's been my understanding that the smaller bore gives more pressure and stopping power using manual brakes. Is that incorrect?
Wilwood makes a 1” bore aluminum master cylinder that I’ve see used. I like the 15/16” from DoctorDiff myself, I use it on all my manual disk mopars. Great line pressure, manageable pedal effort and a good travel range for brake modulation and control.
Exactly so! Smaller master cylinder bore will generate higher brake line pressure, but will result in longer pedal travel. So there is a limit to how small you go, you want to have some extra room before the pedal hits the floor since you'll need more travel when things start to get hotYea, thats right, higher pressure with a little longer travel.
Yup, that would be an even higher line pressure than the 15/16", with slightly more pedal travel. I haven't used one on an A-body but I'm sure that still leaves plenty of pedal travel in reserve.x2, but I personally use the 7/8 master. "Poor man's power brakes"
Sounds right, I think the Diplomats/5th aves used a 1-1/32" in a similar package. DoctorDiff sells those as 1-1/32", or sleeved down to 15/16" (which is what I use).I THINK that the stock 80-82-ish D/B100 master cylinder is a 1.125" bore.
I know-Rick Ehrenberg LIKES the rock-hard pedal.Exactly so! Smaller master cylinder bore will generate higher brake line pressure, but will result in longer pedal travel. So there is a limit to how small you go, you want to have some extra room before the pedal hits the floor since you'll need more travel when things start to get hot
1-1/8" would be a pretty "high and hard" pedal though. Factory sizes for these cars were 15/16", 1" and 1-1/32" depending on the year and brake set up.
Apparently!I know-Rick Ehrenberg LIKES the rock-hard pedal.
Who has one with the four bolt flange and correct size flare ports for the Mopar? Gotta part number?x2, but I personally use the 7/8 master. "Poor man's power brakes"
Getting down to 7/8" m/c bore, you would want to check that there is enough fluid volume for disc brakes.
got a PN?I bought a 2 bolt aluminum master listed for a manual brake 1980 Volare or Aspen and it is 1 1/32 bore. I haven't tried it yet to be able to report on pedal pressure.
