10 vane water pump for 273
Small Block Mopar Engine
  1. Wally-T
    Wally-T 64 Signet
    108
    34
    Jul 14, 2019
    Lindsay, On Canada
    Local Time:
    12:45 AM
    Does anybody know where I can find a new or rebuilt 10 vane water pump for an early style 273? I took a chance with an 8 vane and it overheats in traffic now.
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    58,794
    46257
    Jan 18, 2006
    Iowa
    Local Time:
    11:45 PM
    A waterpump probably won't cure the problem. What thermostat do you have? Has the cooling system been flushed? Are you still using the original radiator? Has it been cleaned or rodded? Any engine work or modifications done lately?
    • Agree Agree x 5
    • Professor Fate
      Professor Fate Push the button, Max...
      1,678
      2165
      Jan 13, 2020
      Wisconsin
      Local Time:
      11:45 PM
      • Agree Agree x 1
      • Demonic
        Demonic Well-Known Member
        1,525
        1203
        Mar 21, 2015
        Maryland
        Local Time:
        12:45 AM
        The rule of thumb - your radiator is dirtier than you think.
        • Agree Agree x 2
        • Like Like x 1
        • pishta
          pishta I know I'm right....
          19,882
          9240
          Oct 13, 2004
          Tustin, CA
          Local Time:
          9:45 PM
          Try overdriving your 8 vane pump of your think its not moving enough water with a smaller pulley or larger crank pulley. You can also tack weld a anti cavitation plate onto your 8 vane and give it maybe more volume. But I'd check timing, mixture and radiator first
          • Agree Agree x 1
          • Wally-T
            Wally-T 64 Signet
            108
            34
            Jul 14, 2019
            Lindsay, On Canada
            Local Time:
            12:45 AM
            I really don't get you guys. Old 10 vane water pump, no overheating. New 8 vane water pump, overheating. It's not rocket science. To everyone else...thank you :)
          • lemondana
            lemondana BlackDart
            652
            407
            Dec 7, 2007
            Southeast NE
            Local Time:
            10:45 PM
            There are a few places in Hemmings Motor News that will rebuild your old water pump if you still have it. These are old school places that have been in business a long time. Better off rebuilding what you have rather than buying Chinese junk.
            • Like Like x 1
            • Agree Agree x 1
            • Bewy
              Bewy Well-Known Member
              540
              286
              Jan 1, 2021
              Australia
              Local Time:
              2:45 PM
              I have done a LOT of experimenting with water pumps. As far as the cause of o'heating, there is something faaaar more important than the number of impeller blades, their shape or their size. It is how well they fit in the cavity they reside in. If there are large gaps around the impeller, the water has an escape route; it just gets churned up/recycled, but is not captured & pumped through the engine. I have often welded a 'donut' onto open impeller blades to capture the coolant & it gives a noticeable reduction in temp.
              This might not be feasible with all pumps, but something to look at/check out.
              • Agree Agree x 2
              • toolmanmike
                58,794
                46257
                Jan 18, 2006
                Iowa
                Local Time:
                11:45 PM
                Just in case you can't find a pump.
                Pulley Diameters
              • volaredon
                volaredon Well-Known Member
                616
                172
                Feb 28, 2010
                IL
                Local Time:
                11:45 PM
                Never heard of 10 vane pump. 6 and 8 are the common ones on a mopar small block. And I had the same issue on my 78 fury 318. Original was 8 vane went to 6 vane and it ran hotter. As soon as I replaced the water pump.
                I had had the radiator boiled out 3-4 times while trying to figure out what was going on. I bought a 3 row champion radiator and a flow kooler water pump. Now it runs almost too cool.
                I think that it would have started running hot soon even if I hadn't had to replace the water pump. If everything is marginal it don't take much to make it run hot.
                • Agree Agree x 1
                • Wally-T
                  Wally-T 64 Signet
                  108
                  34
                  Jul 14, 2019
                  Lindsay, On Canada
                  Local Time:
                  12:45 AM
                  I know. I can't find a pic of a ten vane anywhere. I'll try to dig up the old pump and take some pics to post. Looks like Flow Kooler might be the way to go. They seem to be quite reasonable too. Thanks
                • Rapid Robert
                  Rapid Robert Well-Known Member
                  1,161
                  163
                  Aug 6, 2006
                  Lincoln Nebraska
                  Local Time:
                  10:45 PM
                  & if it doesn't have an anticav plate add one
                  • Like Like x 1
