100 Dollar Hemi!
New Hemi Engine Swaps
  1. Scott's dart
    Scott's dart Well-Known Member
    127
    73
    Mar 25, 2017
    Manitoba
    Local Time:
    8:38 AM
    I just picked up a Hemi out of a 2011 truck for 100 bucks Canadian so like 75 American! The guy said it was running rough so they replaced it without checking what was wrong! Initial inspection looks good so far but I only had time to take off the valve covers and one head! I know the lifters are known to go bad so that's what I was going to check first! Any other reasons it would run rough that anyone can think of? Either way I was willing to take the bet for just 100 bucks! Lol
    • Like Like x 7
    • pishta
      pishta I know I'm right....
      17,262
      6881
      Oct 13, 2004
      Tustin, CA
      Local Time:
      6:38 AM
      check valve height without rockers. if they are all even using a straight edge, your good on a common dropped valve seat.
      • Like Like x 1
      • Agree Agree x 1
      • Scott's dart
        127
        73
        Mar 25, 2017
        Manitoba
        Local Time:
        8:38 AM
        I thought that was the earlier Hemis? Or did it happen on the Eagles as well?
      • rumblefish360
        rumblefish360 So close, yet so far away FABO Gold Member
        38,037
        9721
        Jun 21, 2005
        New York, on a Island
        Local Time:
        9:38 AM
        Doesn’t matter. It’s a quick and easy check.
        Great score! Best of luck!
        • Agree Agree x 2
        • missing linc
          missing linc Loose nut behind the wheel FABO Gold Member
          1,422
          2057
          Feb 17, 2019
          Southern Alberta Canada
          Local Time:
          7:38 AM
          Sweet score!
          • Agree Agree x 1
          • 408 swinger
            408 swinger FABO Gold Member FABO Gold Member
            1,564
            1357
            Nov 12, 2010
            Iowa
            Local Time:
            8:38 AM
            Way more common on the early. 100 to 1 it's the camshaft. Super common on the Eagles. Either that, or, maybe it just needed a tune up!!! Lol, I doubt it. The valve tips are probably wore a little. Common with 150 plus thousand miles. All in all, you did well. You could sell the heads(why would you?!!), and get four times your money back.
          • Scott's dart
            127
            73
            Mar 25, 2017
            Manitoba
            Local Time:
            8:38 AM
            Thanks everyone for the input! I just about bought one for 1300 on Wednesday so i guess good things come to those who wait!
          • famous bob
            famous bob mopar misfit FABO Gold Member
            16,588
            6365
            Aug 14, 2011
            okla
            Local Time:
            8:38 AM
            LOL , I`m still waiting !
          • 408 swinger
            1,564
            1357
            Nov 12, 2010
            Iowa
            Local Time:
            8:38 AM
            I'm guessing for 1300, that one is in a lot better condition!
          • Scott's dart
            127
            73
            Mar 25, 2017
            Manitoba
            Local Time:
            8:38 AM
            Yeah maybe, but with buying stuff from random people on the internet it's much easier to take a 100 gamble over a 1300 dollar one! Lol
            • Agree Agree x 5
            • Hellcat Cuda
              Hellcat Cuda Well-Known Member
              568
              64
              Jan 12, 2013
              Northern Calif.
              Local Time:
              6:38 AM
              Yes, most likely a bad lifter / cam lobe (or more) situation. FCA was replacing cams / lifters for the longest time, but more recently I've been told they are now replacing the whole engine. Also been told they've fixed the problem on '18 up 5.7s. We'll see...
            • Scott's dart
              127
              73
              Mar 25, 2017
              Manitoba
              Local Time:
              8:38 AM
              I finally got around to taking out apart and here's the culprit! It was on cylinder 3! Hopefully that's the only thing wrong with it! 15815439920581685828725506454509.jpg
              • Like Like x 5
              • 408 swinger
                1,564
                1357
                Nov 12, 2010
                Iowa
                Local Time:
                8:38 AM
                Tear it down and thouroghly clean it. Chances are good the bearings are good yet. Has been my experience, anyway. Good luck!
                • Agree Agree x 1
                • Scott's dart
                  127
                  73
                  Mar 25, 2017
                  Manitoba
                  Local Time:
                  8:38 AM
                  So I haven't seen much about this part, from what I gather it's the oil control valve for VVT and MDS? I plan on using a Holley Terminator and deleting all that stuff, do I still need the oil control valve? IMG_20200212_203858~2.jpg
                • 408 swinger
                  1,564
                  1357
                  Nov 12, 2010
                  Iowa
                  Local Time:
                  8:38 AM
                  It is the oil control valve for the VVT. The MDS is the other four solenoids that you removed already. No you wouldn't need it. You'll have to lock the cam phaser(upper cam gear, it's three main pieces) to prevent timing issues. Stanke Motorsports makes a billet plug for the VVT valve. Or just reuse the actual valve as a plug. Make sure you use the NON-MDS plugs for their respective cavaties.
                • Scott's dart
                  127
                  73
                  Mar 25, 2017
                  Manitoba
                  Local Time:
                  8:38 AM
                  Okay great! Thanks!!
                • Scott's dart
                  127
                  73
                  Mar 25, 2017
                  Manitoba
                  Local Time:
                  8:38 AM
                  Here's the wasted lobe, the cam bearings and main bearings are also shot, I only took one rod bearing off and it looked good but I may just replace everything. What brand bearings do you guys prefer? And I've been seeing that the factory used lots of different bearings, is there a particular one I need? IMG_20200213_162417.jpg IMG_20200213_162539.jpg
                • 408 swinger
                  1,564
                  1357
                  Nov 12, 2010
                  Iowa
                  Local Time:
                  8:38 AM
                  That's pickled! For bearings, I've used factory, Engine-Tech, and Clevite. Had luck with all. Pick one for your budget and intended purpose of the engine. Be sure to measure journals to know where you're at.
                  • Like Like x 1
                  • Scott's dart
                    127
                    73
                    Mar 25, 2017
                    Manitoba
                    Local Time:
                    8:38 AM
                  • Cazbah362
                    Cazbah362 Well-Known Member
                    827
                    59
                    Nov 7, 2011
                    Nevada
                    Local Time:
                    8:38 AM
                    Not sure the intent of the build. One thing is, the Eagle 5.7 falls on it face about 6,100 rpm in stock form, this I know from past experience.
                    I really like the 274 cam, and if I was going max power or had to buy a $500 cam, that would be my route.
                    However, my goal was best dollar to HP, so I chose the factory Mopar 6.4 stick cam non-MDS 05037379BC. I called Arrington and ordered the spring kit to match. These where about the same price as what you listed. This cam works nice with factory VVT and all factory parts (less springs kit, but back to what 408 said, inspect and rebuild heads - I agree and feel this was a must for my motor). Make sure you select correct lifters as well (non-MDS), I used these: Melling Factory Hydraulic Roller Lifters JBK-7521. Note, this factory cam is close to the cam you listed in specs. This cam should be about $275 now if you shop around.
                    One thing I would recommend is you gap your rings for power adder, even if you do not intend to add one at this time. Nitrous, turbos and superchargers go well on these, and with it cracked open, this is a perfect opportunity to build for the future. - my .02 cents.
                    And strangely, I like the VVT, all the computers out there manage them, extra bonus... again my .02 cents - This would change if I was going max power or with 274 cam - then its locked -
                    • Agree Agree x 1
                    • Rolling_Thunder
                      Rolling_Thunder Rolling Thunder
                      103
                      22
                      Jun 27, 2005
                      Los Angeles, CA
                      Local Time:
                      6:38 AM
                      Good score = the cam was probably getting replaced anyway so not a major loss there. I scored my 6.1 back in 2008 for $1000 and it needed rod bearings / main bearing.
                      Should be a fun build
                    • Krooser
                      Krooser Reform School Graduate
                      2,320
                      1850
                      Jul 19, 2015
                      Central Wisconsin
                      Local Time:
                      8:38 AM
                      Buy your bearings from Mopar... good prices on good parts. Get to know your parts guy and he may give you a nice discount.
                    • Scott's dart
                      127
                      73
                      Mar 25, 2017
                      Manitoba
                      Local Time:
                      8:38 AM
                      Yeah it turns out this motor is pretty wasted, lots of varnished oil everywhere and the pistons have about 30°-40° of rotation on the rod and then they bind up hard! But oh well still not a loss considering the eagle heads!
                      • Like Like x 1
                      • toplscuda
                        toplscuda Well-Known Member
                        1,972
                        815
                        Jan 23, 2005
                        St. Louis
                        Local Time:
                        8:38 AM
                        At least there is a good side to it getting the eagle heads
