14" or 15" wheels on '67 Barracuda
Tires and Wheels (Mopar Hubcaps Too)
  1. lopeha
    lopeha FABO Gold Member FABO Gold Member
    93
    60
    Mar 8, 2020
    Austin, AR
    Local Time:
    6:48 AM
    Just wondering what you are running and why? Early into my project but like to plan.
  2. Keith Mopar
    Keith Mopar Mopar Nut
    3,178
    1747
    May 15, 2005
    Calgary AB.
    Local Time:
    5:48 AM
    I'm running 14's on the Demon 265 50r14 rear 215 60r14 front on ralley rims, but I did this almost 12 years ago. If I was to do the car today I would defiantly go with the 15's, with way better choice of tire sizes and the decline in 14" choices today. I would also go with the 4.5 pattern unless you are doing an original resto.
  3. 4spdragtop
    4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
    31,226
    11748
    Aug 28, 2009
    Wasting time here
    Local Time:
    6:48 AM
    15", SBP Cragars. This is what the car came with and we liked it. I'm not sure what sizes are, I can check if need be?
    • Like Like x 4
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      20,597
      8033
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      6:48 AM
      295/50-15s on 10s will fit in the factory rear tubs, even lowered if centered.
      235/60-14s on 7.5s fit nicely on the front.
      Don't forget, the factory bolt circle is 4", so that gets to be a bit of a problem when swapping to 15s.
      • Like Like x 1
      • Mattax
        Mattax Just the facts, ma'am FABO Gold Member
        11,721
        7467
        Feb 7, 2013
        Phila. Pa
        Local Time:
        7:48 AM
      • lopeha
        93
        60
        Mar 8, 2020
        Austin, AR
        Local Time:
        6:48 AM
        Thanks for the input! I plan to run Cragar S/S's & they are available in both 14 & 15 in the SBP. Use will be mainly just cruising with the occasional roatrip, no track activity since I plan to keep the 7.25 rear end.
        • Like Like x 1
        • 72bluNblu
          72bluNblu FABO Gold Member FABO Gold Member
          11,460
          6056
          Nov 28, 2008
          NorCal
          Local Time:
          4:48 AM
          Look for the tire sizes you want to run first before you decide on the rim diameter. There isn’t a lot of variety available in 14” anymore. If the sizes you want are available, great! But 15” rims open up some more options.
          • Agree Agree x 2
          • Like Like x 1
          • RedFish
            RedFish Well-Known Member
            24,908
            3299
            Sep 5, 2007
            Local Time:
            6:48 AM
            21570R14 on OEM steel wheels w/ hub caps on my 67 notch. I had 14" magnum 500 road wheels mounted with bolt pattern adapters for a short while. White letter tires too. When I noticed at least 90% of cruise-in participants were rolling on aftermarket wheels, this magnum design being the most common, I went back to the oem/virgin/cherry appearance.
            • Like Like x 2
            • 66fs
              66fs FABO Gold Member FABO Gold Member
              5,507
              2075
              Sep 9, 2009
              Greenwood, South Carolina
              Local Time:
              7:48 AM
              I'm running 15's for the added options on tires.
            • AJ/FormS
              20,597
              8033
              Jan 19, 2014
              Local Time:
              6:48 AM
              If you can, aluminum wheels give a better ride. Generally, they weigh less than the equivalent steel wheels, especially the heavier 5-spoke ones. This is more noticeable with taller and wider wheels. Also,with stiffer shocks.
              • Like Like x 1
              • Mike69cuda
                Mike69cuda 64 is the new 17 FABO Gold Member
                2,172
                1700
                Jan 2, 2018
                Overland Park Kansas
                Local Time:
                6:48 AM
                I went with 15s because of present and future availability of 14s. 15x6 with 195r 60s on front. 15x8 with 235r60 on back wish I would have went one size up on both. Bought the Cragars from Jegs on sale. Free shipping.
                • Like Like x 2
                • Danilo
                  Danilo Member
                  10
                  7
                  Jan 28, 2019
                  canada
                  Local Time:
                  5:48 AM
                  I have a 69 Fastback. Disc brake conversion complete and rear swapped too 5x4.5 bolt pattern. Current rally wheels are 14x5.5 with 215/70/14 and a 3 3/4 backspace.
                  I want to run 17x7 with a 4" backspace. Of course, I have to order online and can't return them when they are mounted... Just not sure if they'll fit. However, the 215 seems quite big for a 5.5" rim....
                  Any sage advice?
                • g413
                  g413 Well-Known Member
                  515
                  125
                  Aug 26, 2014
                  Fresno, CA
                  Local Time:
                  6:48 AM
                  If you're still in the planning stage, now is the time you MUST figure out if you're going to convert to front disc brakes, and if so, what will they be. With 15" BBP wheels, you will have many more choices. Read the fine print from the disc brake suppliers, and do your research. Find out, from other members, the combinations of tires, wheels, and brakes that fit.
                • trapster
                  trapster Well-Known Member
                  2,667
                  264
                  Feb 19, 2009
                  Central Florida
                  Local Time:
                  7:48 AM
                  Decent 14" tires are getting hard to find. go with 15".
                  • Agree Agree x 1
                  • Danilo
                    Danilo Member
                    10
                    7
                    Jan 28, 2019
                    canada
                    Local Time:
                    5:48 AM
                    thanks.... conversion is done - and not by me, so I don't know where from or anything about the conversion.... Just curious about fit... I know it is hard without seeing. Just curious if anyone has been down this road and can help.
                  • 72bluNblu
                    11,460
                    6056
                    Nov 28, 2008
                    NorCal
                    Local Time:
                    4:48 AM
                    You might want to try starting your own thread and including a picture of your brakes. Especially since your question is quite a bit different from what the original poster was asking.
                    • Agree Agree x 2
                    • Danilo
                      Danilo Member
                      10
                      7
                      Jan 28, 2019
                      canada
                      Local Time:
                      5:48 AM
                      will do, thanks.
