Did mopar ever make 14x6.5 SBP (that's the key) steel wheels? In a parts book it shows 14 x 6.5 but doesn't call out bolt pattern. Shows it was used on station waggon.
Max I have seen are 5.5 steel for small bolt. If you are looking for wider wheels you should be able to I take the wheels down to a wheel manufacturing company like Stockton wheel , Wheels America, etc and have them enlarged to your liking. 14x6 14x7 15x7 etc. I did this recently and Stockton wheel I think charged 135 a wheel.
Thanks...
My biggest issue is that the tapers on all my wheels is distorted from 51 years of impact wrenches mushrooming the steel. So that's why I figured if I am searching for wheels might as well go wider.
Don't want to stray from 14" (OE hubcaps) and don't want to go BBP. 10 years from now I might not have a choice as 14" tires are fewer and farther between and I suspect will only get harder to find in the future.
