15 x 7s, what size would you run on a 68 four door dart ?
I put 215-70R15 on front of my car and had to trim over 1/2 inch off lower front edge of front fender to clear. But was able to hide the pie cut behind the wheel well molding. No rubbing anywhere after that. Big bolt 11 3/4 front disc and Wheel Vintique 15x6 with 3.75 backspace. That wheel is regularly stocked at Summit Racing.
I put the YJ rearend on the springs - the pads fit perfect, wouldn't even have to weld- but have 3" wider on each side for a total of 6". Tire will rub, even with 205s on stock steelies. So I am ordering new axles for the 7/1/4 unless someone here sells me a set of BBP.
