fireman
Member
is it possible to tell if this is a 170 or 225 from this picture?
It's all about that radiator hose connection from the front of the head to the radiator
The bypass hose You're going to look at is about 1.5" or so if it's a low-deck "G"170, about 3" for the tall-deck "RG"225 & 198. The difference in deck ht. is approx. 1&5/8". From the photo it appears to be a 225, & depending on the vintage, there will be either a "17" or "22" for mid 60's & down, or the actual 170/198/225 on the deck pad next to the alt bracket.............................Awesome. Thanks guys. I’m going to see it tomorrow so I’ll measure that water pump hose
Most likely a 225 because it has a holley carb. The BBS carbs were used on 170 engines mostly.
Ok. Went and actually bought the car today. It did in fact have a Holley carb. I know this does not necessarily denote it being a 225. Turns out it is a 225 though. The hose was about 3 inches long and the air filter cover had the “charger 225” sticker on it. Thanks for the help guys! I’ll post pics and the car story on a new thread.
My 1963 service manual show only holley carbs used on 225s the bbs was used on 170s and 225s the picture shows a holley carb as the fuel line is entering the carb on the left a bbs enters the carb from the front. The car appears to be a 66 and a California emission's because of the air cleaner and the vacuum controls at the right rear of the engine. Anyone with a 66 service manual that can confirm that in 66 They used holleys on 225s? The gentleman asked a simple question with only the picture to go on. And yes I agree that a 53 year old car could have anything under the hood.That's a very old myth, and it is not correct. Carter BBS and Holley 1920 carbs were both factory-installed on 170s and 225s in most years between 1962 and 1969 (pre-'62 only BBSs). Moreover, the car in question is roughly half a century old; plenty of time for plenty of carb-swapping.
