[SOLD] 18 Spline Hemi Hydraulic clutch kit Mcleod
Swingin1970
Santa Barbara CA
Complete 18 spline (23 spline Jack Screw avail from Mcleod) 833 trans hydraulic clutch/throwout bearing kit. Used very little 12 passes.
Mcleod Racing 1400 series Hydraulic slip on bearing: Paid $500.00
American Powertrian HydaMax master cylinder kit: Paid $385.00
HYDRAMAX Firewall Mount - Pat. Pending Adjustable Bracket, Nickel Plated
Wilwood 3/4" Master Cylinder - Black finish, low profile
Line Fitting - 90-degree O-ring boss to -3AN
Pedal Rod Assembly - Model Specific
Conversion Fitting- Allows use of -4an McLeod Bearing and others
Reservoir Kit - Standard plastic tank.
Complete bolt in kit to convert mechanical linkage to hydraulic system. Very easy install complete installation instructions from American Powertrain included and gives a ton of room around headers. Our new clutch requires a mechanical bearing.
Ill take $550.00 shipped for the entire kit.
Custom Billet aluminum master cylinder push rod and custom aluminum bracket to attach reservoir to brake master cylinder included.
