I have my Holley 1920 running what I would consider nearly perfect so this question is more of a curiosity. I scoured the FSM and don't see where it mentions which hole the link rod on the accelerator pump should sit in. When I got my 66 Valiant it was in hole "3" aka closest to the firewall. I realized when I put the carb back together I hooked it in hole #2. The car drives wonderfully and moves along just fine. No stumbles, stammers or anything. I'm running a #58 main jet and worked over the entire power valve assembly so that it actuates on time and closes up correctly. The picture below is from a stock photo and not mine. If I'm not seeing any driveability issues should I even bother moving it? I assume this just controls how quickly the pump sprays fuel?
