mario03srt
All,
I have a issue with removing the passenger door card to get at the internals. The window crank is stuck up, and the door latch is inop from the inside. These do not have a screw(s).
I pushed back the door card to see in behind the handles and do not see the retainer clip. It must be recessed or flush with the handle it self. I tried the rag behind handle to try and get the un seeable clip to slide off but no go. I have the original service manual and it indicates that special tool C-3448 is used to squeeze a clip that on the shaft.
Does anyone have a work around to remove these or a tool to loan?
Thanks,
Marion
Thanks,
Marion
