Since She Who Must Be Obeyed has already spoken, this is probably a moot point, but I did it with Schumacher mounts and torque strap. The distributor does clear the firewall without modifications if you get rid of your heater box. A certain factory exhaust manifold will fit, but I forget the part number. And I used a pushbutton 727 (actually I think it's an A488 ) rather than a 904. I had to enlarge the transmission tunnel a little for the A488. There's not enough hood clearance to install a spacer under the carburetor, which I think causes certain hot start problems, so you might want to install a hood scoop in order to raise the carburetor up a little. I had a larger, thicker radiator made and constructed my own fan shroud.
