its a slant pushbutton wonder, started as a roller, still a roller!! LOL...... I got fuel and spark and fired it for a second. and shut if off. it was roller missing throttle rod. have an extra one for the 65 slant dart. well looks like the 63 rod is maybe like 1 1/2 in shorter than the 65 . ( different firewall )....
I can cut and w eld the 65 rod but will the part on inside that attaches to pedal be correct....???????
probably better to see if I can get 63 rod linkage. I have the kickdown parts, just need the throttle rod. I will post in parts wanted too, but hopefully the powers will leave this here too. if the inside part is the same as the 65, it would be easy fix but don't mind paying for correct rod.
I found a cable shift tranny for it I hopefully can get in few weeks. the A100 tranny won't work)....getting the itch to take it at least around the pasture ( sorta like yard drive!???)
