I have a pair for turn signal housings from a 65 Valiant. They are really clean on the inside with no rust, so I figure they should
work fine. PO had cut the pig tails, so they would need to be spliced back on, if one has original housings with wiring. $20.00
each housing plus the ride from El Dorado Hills, Ca. PM me if interested. All mounting studs are intact.
