[WANTED] 1964 904a transmission (push Button) torque converter.
Cars and Mopar Parts Wanted
  1. Stinktooth
    Stinktooth Active Member
    42
    1
    Feb 7, 2012
    Sayville,NY
    Local Time:
    5:20 AM
    Contact Seller
    Wanted local pick up for Long Island N.Y. 1964-65 , 904 torque converter I think its a 18 spline shaft. 66 and up will not work with my push button trans.
  2. Charrlie_S
    Charrlie_S Well-Known Member
    3,182
    1017
    Oct 17, 2005
    Silver Springs, FL
    Local Time:
    5:20 AM
    Actually, 60-67 will work. If you don't find anything locally, I have a couple, but I'm in Florida
    • Like Like x 1
    • Stinktooth
      42
      1
      Feb 7, 2012
      Sayville,NY
      Local Time:
      5:20 AM
      The LA motor was first produced in 1964 so what would fit on that from 1960? A converter from a slant? I am trying to learn about these things so I don't trash the input shaft on the transmission. I had a tranny shop already destroy the tranny when he put a later model planetary in the unit and then hooked up my original Torque converter, it sounded like a blender when the engine was started.
    • valiantwagonguy
      valiantwagonguy Well-Known Member
      960
      660
      Oct 20, 2005
      Long Island
      Local Time:
      5:20 AM
      I have one from a 65 Barracuda .I'm in Huntington Long Island and the factory ones are the same for the six and the 273 in 65 and 64 .Probably a little later too.What is it going behind ? Where you run into problems is with the crank flange on the later 68 and up motors.They are a different size .
      • Like Like x 1
      • pishta
        pishta I know I'm right....
        19,135
        8552
        Oct 13, 2004
        Tustin, CA
        Local Time:
        2:20 AM
        I got a rebuilt one on the left coast.....
        • Like Like x 1
        • Stinktooth
          42
          1
          Feb 7, 2012
          Sayville,NY
          Local Time:
          5:20 AM
          I am in Sayville
          I need a core to send out. I have the original 273 and tranny for the valiant but need a core to have set up for 2400 rpm stall. Doing a cam and head swap on the motor.
        • valiantwagonguy
          960
          660
          Oct 20, 2005
          Long Island
          Local Time:
          5:20 AM
          Biltron builds them and they are right here on the island .They will make it to whatever you need and are reasonable Rebuilt Torque Converters — Biltron Quality Automotive Remanufacturer
          I had one made there with a later front and the earlier back when I put in a later motor in front of the 2 cable trand in a 65 Valiant .They are very good .
          • Like Like x 1
          • Stinktooth
            42
            1
            Feb 7, 2012
            Sayville,NY
            Local Time:
            5:20 AM
            wow that is 3 miles from my house! I will check them out tomorrow Thanks!
          • valiantwagonguy
            960
            660
            Oct 20, 2005
            Long Island
            Local Time:
            5:20 AM
            Your welcome ! I've used them a few times and so have a few of my friends. If you still need a core let me know I have one I can dig up.
            • Like Like x 1
            • Stinktooth
              42
              1
              Feb 7, 2012
              Sayville,NY
              Local Time:
              5:20 AM
              Thank you I will let you know how i make out. I am going by in the morning.
            • Stinktooth
              42
              1
              Feb 7, 2012
              Sayville,NY
              Local Time:
              5:20 AM
              I stopped in and spoke to the owner, he said he could help me so I am planning on getting my converter to him this week.
              Thanks for the info
              • Like Like x 1
              • valiantwagonguy
                960
                660
                Oct 20, 2005
                Long Island
                Local Time:
                5:20 AM
                Great,they do good work .
