I have used the laysons version before and was quite disappointed when it tore after a few months and they would not help me out. I compared the material they used with an original boot. Laysons is a different material that is not as strong. So here we go again s*** out of luck for us early a body guys. Then I found a Mr. gasket boot, #1651 for 25.00. I have been using this boot since the late 90's. The trick with this one is to mount it, I used soap to get it to slide down the shifter handle, then drill new holes in the floor with the sifter in neutral. If you try to install in your factory screw holes you will tear the boot, as I have done. Its a good boot and if I was not always messing with my barracuda would likely out last the garbage laysons i producing. Amazon has the boot for 21.61
