1964 dart idler arm question
Suspension, Steering and Chassis
  1. Naplm00
    Naplm00 Well-Known Member
    233
    50
    May 20, 2019
    Bay
    Local Time:
    6:02 AM
    I ordered a centric 620.63003 idler arm for my car since that's what rockauto called for.
    after disassembling the front end I found that my idler arm is totally different.
    I also can't seem to figure out what type of idler arm is have. I do know that on the chassis there is nowhere for a taper on the car side for a double taper one to fit. On the car side I definitely need the style that uses a bolt and a bushing.
    Can somebody help me identify what I have on here so I can buy a replacement?
    What I need looks like this one : https://m.autozone.com/suspension-s...arm-fa1012/dodge/dart/202952_148976_2793?aqs=
    But the taper pin is inverted.
  2. Naplm00
    233
    50
    May 20, 2019
    Bay
    Local Time:
    6:02 AM
    Here is the hole in the k member. I put the rockauto arm up there and it fit but seemed loose
  3. Naplm00
    233
    50
    May 20, 2019
    Bay
    Local Time:
    6:02 AM
    Well I cleaned it up and did a little bit more digging. It really didn't seem to me that this had any taper to it whatsoever. I was wrong.
    I inserted a ball joint that had a similar taper to the new rock auto idler arm, And it fit perfectly.
    I'm thinking that somebody put on the wrong idler arm who knows from what. And at the RockAuto arm is probably correct. I took a better picture after I cleaned it up.
    Any input ?
  4. Dana67Dart
    Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
    5,561
    3561
    Jul 16, 2017
    Northern Colorado
    Local Time:
    7:02 AM
    67 uses similer tapered at both ends idler arm, 68 up uses thru bolt like you took off.
    I would measure both sides of the taper on the car to be sure it really Is tapered.
    One more thing. The geometry of the idler arm should be very much the same as the steering arm
  5. Naplm00
    233
    50
    May 20, 2019
    Bay
    Local Time:
    6:02 AM
    Doesn't the through bolt style use this type of k member ?
    It's definitely tapered , the ball joint was a perfect fit.
    I have a pitman arm on the way
    https://www.engine-swaps.com/Photos4Website/TechInfoPics/KMember_Photos/KMember AOB.jpg
  6. RustyRatRod
    RustyRatRod Lemmie see your b00bs. FABO Gold Member
    67,582
    41756
    Jun 7, 2010
    Georgia
    Local Time:
    9:02 AM
    You ordered the correct arm. You had the incorrect arm on the car.
    • Agree Agree x 1
    • Naplm00
      233
      50
      May 20, 2019
      Bay
      Local Time:
      6:02 AM
      Great thank you. I had my passenger side wheel (The side with the idler arm) rubbing on my front fender when the driver side was perfectly okay. Hopefully this was the culprit
    • Dana67Dart
      5,561
      3561
      Jul 16, 2017
      Northern Colorado
      Local Time:
      7:02 AM
      Thru bolt style has a different bracket. No taper. 1/2 is above the idler 1/2 is below.
      Look at lower right of image.... This is a 68 up k member. The idler you pulled off might fit it but not your car.
    • Naplm00
      233
      50
      May 20, 2019
      Bay
      Local Time:
      6:02 AM
      Yea I posted a pic of the other type , all figured out now ! Thanks !
      • Agree Agree x 1
      • C130 Chief
        C130 Chief Mechanical Genius
        3,076
        233
        Nov 23, 2005
        Boise, ID
        Local Time:
        7:02 AM
        So you want the center link to be parallel to the ground in the greater scheme of things.
