1964 dodge dart carb problem
Slantsix64
SSG
hey guys so i took apart my carb on my 64 dart 225 it has the stock one barrel bbs carter i did not mess with anything but the gaskets for the bottom and top of the carb and sprayed carb cleaner under the jets to get out some dirt and now my car is idling horrible and back firing try adjusting the mixture and idle but no sucess it wasnt like how i had it previously nice and smooth i dont understand why this has happened i have rebuilt 3 carbs like this and never had a problem and this time all i did was change out the old gaskets the thicker one on the base of the mainifold and two thinner ones on the carb any ideas???
You might have put the bottom basket in wrong. If memory serves it can go in two diff ways. But my memory is not what it used to be. vacum leak.
