[SOLD] 1965 273 Commando Engine & 904 Assembly
typopup
Stettler, Alberta, Canada
Rating - 0%
0   0   0
273 Commando w/ std bore, forged crankshaft, adjustable rockers, 4 bbl intake ... I do NOT have the Commando valve covers though.
This engine was running when removed (aren't they all!!) but blowing some smoke on acceleration.
Included is a similar aged 904 transmission (includes converter w/ smaller pilot) that I was told was working as well.
This engine was stored in a garage where a lot of wood working was being done ... hence the light sawdust covering in some of the photos. I would definitely recommend a complete disassembly & a good cleaning before anything is done to the engine.
This assembly is in Alberta, Canada so make sure your dog sled team is strong enough to pull this home.
I knew there was something I was forgetting ...
$350. USD for everything ... will sell engine separate from transmission if need be, but not individual parts.
Casting date for the block is 12-21-64 ...
Date stamp on block is A273-7-26 ...
Casting # for the intake is 2465726 ...
Casting # for heads are 2465315-1 ...
