barracudajohn
Was in a car that parked for years. I don't know if the shifter mechanism can be freed up, it is very rusty. I removed the side levers on the trans. and moved the shift forks with a wrench and was able to actuate all of the gears. Selling as is. I did not remove the side cover to inspect the condition of the gears. Located in ZIP 18038, must be picked up. Was in a 1965 Formula S. 450.00
