Hi Guys,
Sorry I missed coffee this morning. Belive me I coulnt sleep, I was awake....up all night trying to make budet decisions.. like pay the morgage or order the short block.
Short block ordered, I can pay the morgage next week haha. I will try to get a quick coffee tommorow morning.
I did want to discuss the pland and build for this car. And get your feedback, because, you guys have see all of what Im doing ....and know the ups and downs.
And, please constructive critisism is appreciated here. I dont mind being told point blank yes, no and maybe not..lol Im a nebwiee to mopar
Lets talk motor and transmission: my personal favorite the grits on it all
I like the 408 for this Barracuda, first : with the aluminum heads it shouldnt be any much heavier than the iron headed 273. Decent power, still on a diet up front.
I like forged crank, forged pistons and forged rods. Weather or not it, will stay together isnt the issue. I once droped an air cleaner washer right down the carb and the forged piston just blew it right out. Also thinking ...hopefull it will help with sleepless nights. Unfortunatly I was sort of pushed into the Magnum block, 408 as the magnum is more readily avalble.If I had my choice it would be all LA. that ship has sailed .
Mini drum roll please (lol) The budget short block came in at $4192 at Jegs.....order placed for the ATK SP57 Magnium. If I remeber correctly with the 61775 edelbrock rpm heads (yes, I know I wanted LA heads too) the compression ratio should be around 10-1... heads are good to about 500HP acorrding to edelbrock. Have not purchased the heads yet, I was close to getting the AFR, was in que and didnt want to deal with machine shop woes, been there done that. were not doing sleeves on a old rusty virgin block. Just send the block and rods bolted together and Ill slap a cam and heads on the mother. Ill be happy with 400HP. If I need to go faster, I grab my other car.
"Transmission" I happen to like the TKX 5 speed. send it all, new wave clutch pedal, metal hump, clutch and bolts, swap the crossover what ever it takes. Got a quote for around $5,500. it probably wont fall apart because it to old,go maximum over drive ,the engine should make up for the wide range gears. street car...aftermarket ac if theres any money left.
Hiway rear end, 411, 565, not for me, how about HI WAY oriented. Pull the old rear end out toss in dumpster and replace.. no idea where to get it..maybe youface or tick tock..
Suspention: drop the car an inch or 2. I learned 2' drop sounds good, found out it like dropping the car a mile on a previous build. we drop the car unti it feels right. Im guessing the Barracuda guys know best, about suspention upgrades and wheel fitment and rear end set ups. Lets do steel wheels, just big enought to fill the wheel wells while the car is dropped just tht 1.5" and keep the plaine Jane hub caps, as long as they stay put under tire spin...... please advise on how to get those wheels and height just right LOL.
My second favorite part: looks that kill; based on this requirment we need two things. Correct fitting wheels (dont need to be wide just fit right) and Super straight spotless black paint job. chrome can be a tiny bit hazy but paint has to be great. Fortunatly I sorta got this one. Im my home garage I would scuff the whole car, Do any body repairs, shoot with PPG shopline epoxy primer. Mud where we need mud. Shoot a gallong of slick sand, block the **** out of the car then shoot a gallon of feather fill.. Block again and again you get it... should look good in black feather fill for a time, real good. Then we have my autobody pal do a final block sand, shoot the sealer and black and clear at his place of buisness, a genuine certified spray booth.
Ive had some cars under restoration for years and years. this is not that car. Its not going to win any shows, just want it to be fun!
Ive attached pictures of the car as it stands today, havent taken off the trailer yet..
the other pictures are just a renderings my my son did. I do not like the wheels or profile of the wheels, I think stock hub caps would look better, and actully.. lets do steel wheels backspaced properly, lets drop the car and take a look..
any and all advise is appreciated, thank you
