1965 Cuda Gas gauge.......
Discussion in 'Early A-Body Discussions' started by Banjoman09, Aug 6, 2018.
  1. Banjoman09
    Banjoman09 Well-Known Member
    65
    3
    Jul 15, 2018
    Pratt, Kansas
    Local Time:
    4:10 AM
    Now that my Turn Signals work fine- my next problem. I installed a new reproduction gas gauge about a month ago- never has worked right. Sometimes it comes up- sometimes it doesn't. I took it down and filled the tank today- went up to 3/4...by the time I got home it was back on empty. I even installed an extra ground wire from the frame to the tank! Any ideas? Thanks.
  2. Murray
    Murray FABO Gold Member FABO Gold Member
    376
    126
    Apr 19, 2010
    San Jose, California
    Local Time:
    2:10 AM
    Ground the sender unit wire. Gauge should immediately go to full. If not, you have a problem with the sender.
    • Agree Agree x 1
    • spycam
      spycam Active Member
      43
      7
      Apr 15, 2016
      California
      Local Time:
      2:10 AM
      1) did the previous work ?
      2) did you check the sending unit ?
      3) are the other gauges working ?
      4) did you replace the existing one or bypass it ?
      5) search these forums for "gas gauge" there are many entries.
      I did the conversion to a solid state gauge voltage regulator so I have a solid 5 volt reference and replaced the sending unit and everything works fine with the old existing gauge. There are some fantastic articles on that and I just followed them.
      • Agree Agree x 2
      • Banjoman09
        65
        3
        Jul 15, 2018
        Pratt, Kansas
        Local Time:
        4:10 AM
        I replaced the old sending unit- old one was not working. All gauges are working. How do I access the old forum gauge discussions? Thanks.
      • spycam
        43
        7
        Apr 15, 2016
        California
        Local Time:
        2:10 AM
        On the upper right-hand side of this screen there is a "search" text box. Type "gas gauge" and press ENTER. You can type more specific keywords also like "gauges 65 Barracuda" etc
      • Banjoman09
        65
        3
        Jul 15, 2018
        Pratt, Kansas
        Local Time:
        4:10 AM
        Thanks!
      • spycam
        43
        7
        Apr 15, 2016
        California
        Local Time:
        2:10 AM
        Unfortunately new unit doesn't always mean working unit. Especially with all the Chinese crap nowadays. You still need to test it and assume it's bad.
      • Banjoman09
        65
        3
        Jul 15, 2018
        Pratt, Kansas
        Local Time:
        4:10 AM
        I ordered another new sending unit from "Laysons Restorations"...they seem reliable but also said there are NO sending units made in the USA. I will adjust this new one so it is right(with my Ohm meter) I will have to find the specs...I did check my wire coming from the gauge and when I ground it the fuel gauge immediately goes to the right. Thanks.
      • Banjoman09
        65
        3
        Jul 15, 2018
        Pratt, Kansas
        Local Time:
        4:10 AM
        I received my new tank unit today-Anyone have the Ohm specs on full and empty..and is this adjustable? Thanks.
      • Banjoman09
        65
        3
        Jul 15, 2018
        Pratt, Kansas
        Local Time:
        4:10 AM
        I just checked my new one; reads .08 at empty and .01 on full; that doesnt sound right to me.
      • Murray
        376
        126
        Apr 19, 2010
        Local Time:
        2:10 AM
        Yes this is adjustable. There is an empty stop and there is a full stop. Adjust these to achieve the correct readings.
      • Banjoman09
        65
        3
        Jul 15, 2018
        Pratt, Kansas
        Local Time:
        4:10 AM
        Which are?
      • spycam
        43
        7
        Apr 15, 2016
        California
        Local Time:
        2:10 AM
        When the tank is full the resistance of the sending unit's pot is the lowest (typically 10 ohms, float up) so that the maximum current can flow through the gauge and the needle can swing fully to the right. When it's empty the resistance is the highest (typically 73 ohms, float down) so that the minimum current can flow and the needle stays on EMPTY.
        If you are reading your meter on the 1K ohm scale you're about right (0.01 X 1000 = 10 and 0.08 X 1000 = 80 ohms).
      • RustyRatRod
        RustyRatRod Just another dumbass. FABO Gold Member Technical Editor
        45,680
        9681
        Jun 7, 2010
        Georgia
        View My Photos
        Local Time:
        5:10 AM
        It is probably true there are no sending units still made in USA. You can do better than China, though, by getting a Spectra sending unit. They are at least made on North American soil in Canada. If that's not what Laysons sells, I would not buy from them.
      • halifaxhops
        halifaxhops I guess I have a gold member no one likes? FABO Gold Member
        42,792
        11788
        Jan 20, 2014
        CENTRURAL, PA
        View My Photos
        Local Time:
        6:10 AM
      • Banjoman09
        65
        3
        Jul 15, 2018
        Pratt, Kansas
        Local Time:
        4:10 AM
        Ok I'll check again- using scale 20k- screen reads .08 empty and .01 full. Thanks
      • halifaxhops
        42,792
        11788
        Jan 20, 2014
        CENTRURAL, PA
        View My Photos
        Local Time:
        6:10 AM
        Here you go
      • Banjoman09
        65
        3
        Jul 15, 2018
        Pratt, Kansas
        Local Time:
        4:10 AM
      • halifaxhops
        42,792
        11788
        Jan 20, 2014
        CENTRURAL, PA
        View My Photos
        Local Time:
        6:10 AM
        Put your meter on the lowest ohm setting way more accurate. Also shoot the continuity of the sending wire should be near zero, wiggle it also if you can can be something simple also.
