1965 Dart Blower motor wiring
Electrical and Ignition
  1. MichaelD
    MichaelD New Member
    4
    0
    Dec 2, 2019
    Richmond, Virginia
    Local Time:
    2:33 AM
    I have a 65 Dart and I am replacing the broken heater blower motor. When I removed the heater box I noticed that some wiring was hanging loose. I thought I could figure it out as I had a wiring diagram http://www.mymopar.com/downloads/1965/65DartA.jpg for the car.
    My problem is the diagram shows the wiring to the switch and resistor but NOT to the blower motor, or any grounds. I have hooked up everything but am left with two brown wires joined at an eyelet terminal. Are these brown wires supposed to be the blower motor ground????
    They were loose when I started and suspect that they should be screwed down (as it is an eyelet terminal) to achieve ground - but I am not sure. Any advise appreciated.
    Thanks.
    Michael
  2. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    10,567
    2349
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    2:33 AM
    As you surmised it is secured with a screw and is the ground for the heater. Pull the passenger kick panel and you should hopefully find a hole where it’s fastened.
  3. MichaelD
    MichaelD New Member
    4
    0
    Dec 2, 2019
    Richmond, Virginia
    Local Time:
    2:33 AM
    Thank you 65 Dartman. Any idea why the wiring diagram leaves the blower motor out.
  4. MichaelD
    MichaelD New Member
    4
    0
    Dec 2, 2019
    Richmond, Virginia
    Local Time:
    2:33 AM
    I looked at the car this morning and the brown wire is screwed into the body behind the kick panel. This loose wire (actually two wires in the eyelet) has been just flopping loose on top of the heater box. It should screw down somewhere - but I don't see where. Any suggestions?
  5. 65 Dartman
    10,567
    2349
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    2:33 AM
    I’m not exactly sure but suspect it might go to the blower motor. On my 65 there was only 1 wire in the eyelet.
  6. 65dartcharger
    65dartcharger FABO Gold Member FABO Gold Member
    6,659
    1676
    Dec 9, 2006
    Tavelsjo, Sweden
    Local Time:
    8:33 AM
    Which colors on them?
  7. 65 Dartman
    10,567
    2349
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    2:33 AM
    i just looked at his original post and the wires are brown
  8. Murray
    Murray FABO Gold Member FABO Gold Member
    1,207
    719
    Apr 19, 2010
    San Jose, California
    Local Time:
    11:33 PM
    Brown wire is a ground and is screwed through the retaining bracket holding the two heater core tubes were it exits the box and goes through the firewall. The end of the brown wire is grounded behind the right kick panel.
    • Like Like x 2
    • Agree Agree x 1
    • MichaelD
      MichaelD New Member
      4
      0
      Dec 2, 2019
      Richmond, Virginia
      Local Time:
      2:33 AM
      THANKS
    • Mattax
      Mattax Just the facts, ma'am FABO Gold Member
      8,029
      4678
      Feb 7, 2013
      Phila. Pa
      Local Time:
      2:33 AM
      Get the shop manual from the same website. The factory wire diagram is in the back of th electrical chapter. They are not perfect but they are better than what you have linked to. That's ripped from a Chiltons or Mitchels or the like.
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      40,497
      8134
      Oct 14, 2010
      Idaho
      Local Time:
      11:33 PM
      This is something many guys on here do not seem to understand. So to make this clear if you can find an applicable FACTORY service manual to download there, and you might have to settle for Dodge instead of Plymouth or other way around, that is "usually" the most accurate, although some years DO HAVE errors
      The "other" wiring diagrams there at MyMopar (all two pages) are NOT FACTORY wiring, and often leave out options, or mark connectors poorly, etc. They are however useful, and sometimes easier to follow than factory ones.
