two fords
This is a true V8 GT, I have done the following work:
Reinforced the upper control mounts (I had a 440 in it was going to build as race car) all new bushings in the front end.
8 3/4 posi rear with extended race studs
Steel rear wheels with new tire
Rebuilt rear springs
Four new adjustable race shocks
Fully adjustable rear end mounts
Ladder bars )not installed
Chassis connecters installed
4 wheel disc brakes with dual master cylinder, all new brake lines (hard and flexible) and adjustable proportioning valve
Alloy 5 spoke wheels with new tires
Have all chrome and S/S trim
New full patch panels
All seats are reupholstered
Have new carpets
New 100 pound bus battery mounted in trunk and wired to kill switch
Gas tank sump (not installed)
Engine:
Chrome oil pan, Mickey Thomson Valve covers
New big block radiator
Rebuilt 360
Street roller cam
X heads with double springs
Air gap manifold
All parts to run engine (starter, alternator, pulleys
Transmission is a 727 automatic
I have so many parts I may have forgotten some but all will go with car
Email robertpodgurski@yahoo.com for more detailed pictures (can't upload) or call(732) 632-2768 for appointment to see
Clean Title in My Name
$8500.00 At this time I am some what negotiable.
THE 440 Cross Ram is no longer in the car. It has a new 360
I have it listed under parts.
Have new carpets
Engine:
Rebuilt 360
Street roller cam
Air gap manifold
