1966 Barracuda Formula S on Bring A Trailer NOT MINE
I thought they all had 8 3/4.
This one is REALLY early in the production year at Hamtramck/Dodge Main. My NOVEMBER 10, 65 manufactured commando 273 (BP29D62555048 - the 55,048th vehicle off the line at Dodge Main) had the 8.75 Sure Grip. This one is an AUGUST 18, 65 (BP29D62502174 - 2,174th vehicle off the line at Dodge Main) vehicle, which was a "first couple weeks" of production car if they started first of August 1965 for 66 model year production. Note also the valiant badging on the grill center and back window....that is also EARLY 66 model year stuff.
Also, I understood that the PAINT code was PAI for the main body code, N for stripe, and T for Interior Door upper color. The Clip form the fender tag decode document is here:
"Under the “N” for the stripe on the roof will be:
B = black
W = white
H = red
Q = red
E = blue
8 or blank = no stripe"
This leaves the N as a mystery here as it is an "S" and the Car has no racing stripe (but it DOES have the std body side stripe). For a Dark Green (GG1) car the available stripe colors would have been only Citron Gold and that is not in the list for the fender tag decode and "could" have been S, but the SS1 code was Soft Yellow and that was not a racing stripe color. I bet the Citron Gold racing stripe letter was Z to match the paint code elsewhere, but if anyone has a citron gold stripe and a fender tag please post it. most of the codes in the fender tag decode correspond to the paint codes B = black or BB1, W = White or WW1, Q = Dark Red or QQ1, E = Dark Blue or EE1...the outlier is H as that is not a paint code, but there IS a second red as PP1 is bright red.
Anyway... :-)
B = black
W = white
H = red
Q = red
E = blue
Anyway... :)
I suspect they didn't start on the 1st of August. My '66 SO date is the day before this one (8/17/65) and has a 499 VIN. That's 1,675 numbers before this one in only one day. They didn't always get built in exact VIN or SO number sequence, but, that still seems like a big gap for one day. If that gap is consistent, Mine must have been built the 2nd day of production. I've looked at '66 Barracuda VIN's for over 40 years now and haven't found an earlier one than mine. Still lookin though! :lol:
What plant made yours? The Hamtramck/dodge Main started the Ser. no at 500,001 for A body Valiant/Dart models, for some reason, or so the published sources say (For example, "Each Plant consecutively numbers all vehicles beginning at 100001, regardless of car make or model, except Hamtramck built Valiant and Dart models which begin at 500001." at https://www.geocities.ws/MotorCity/Speedway/9048/vin.html ). Although the Barracuda was made at several other plants that did not use the 500,001 as first one (st. louis for example and LA). A 1966 vin with 499,*** is another MoPar mystery if it was a BP29D62XXXXXX.... almost like they were just making cars and not worrying about a bunch of us trying to make sense of it 60 years later.
I wonder if the SO Number format also differs, as all my Dodge Main produced ones i have owned or have seen in mags and on line have Axx for date of manufacture with a letter for the month whereas the ones I have seen with the 3 digit, all number, mfg date on the fender tag are not Dodge main manufacture....Food for thought. My sample is small as I have only owned a couple 66's and seen maybe 40 others over the years in person or in junk yards and have never seen a non Dodge Main manufacture one in the wild here in the KC area with a fender tag. Saw ONE NY car in a junkyard back in the 80's in Lawrence, KS but it had no fender tag (that was the only NY Flasher car I have seen in IRL).
Anyone have a source that says WHY Hamtramck started at 500,001 for dart and valiant models?
Near as I've been able to determine, they only made the '66 Barracudas at Hamtramck (2) and Los Angeles (5). I have both, but, the one I referred to is a Hamtramck car 500499. A very strange car as it was originally shipped to International Motors in Honolulu Hawaii. It has all the Formula S options, but, not a FS! It has an 8 3/4 and disc brakes too. It's as if they ordered everything separately instead of checking the package box. Also has buckets, console, 4 speed, and a rare heater delete. The only thing I can think of as to why it went all the way from Hamtramck to Hawaii instead of from LA is that the LA plant must not have been swapped over to the new model yet and wasn't ready to ship all the new show room models. I suspect Chrysler wanted all the new models to be in all the show rooms around the same time, so. to get one going on it's long journey, off this early production car went to HI. It has the buffed silver paint with a red interior, which is also a good indication it was a show room car.
I've owned about 20 '66 Barracudas, (still have 3) and not one had the racing stripe! In fact, not one was equipped the way I would have wanted if I had ordered one new. The 4 speed car comes close, but, a red interior does nothing for me. I would have ordered the rear window defroster and quick ratio steering too, which one of my others has.
I’ve had many comments over the the yrs why I didn’t put the stripe on it, because it never had one. I’m surprised you never had one having owned that many
FWIW, a number of sources say that the first gen barracuda was also assembled at St. louis, although I don't find consistent entries as to north or south plant. The North plant opened in 1966, so for that model year it's a toss up. Of course, the sources have circular references, but even Wikipedia is pulling the same language. Can anyone verify a 66 with a BP29D67XXXXXX serial number?
I've looked at several hundred 1966 models in the last 45 years and haven't seen anything but LA and Hamtramck.
I can recall not so long ago a first gen Cuda , you had to give them away!
They just need bigger wheels/tires!!
Yep, back in the 90’s it seemed like I was the only one doing an early A body. Guys at the Nationals we’re waiting for me to show up because they had really nice parts, and they knew I was buying. Besides my friend who was racing her early Barracuda, I can’t recall any early Barracudas, and certainly no early Darts, at any shows. I got a lot of nice parts for my Barracuda, and got one of the first sets of Spitfire headers directly from Harold. He was using my friends Barracuda as his mock-up for the headers, and she told me to call him as he had just got them done and ready for production. $188 to my door in 3 days.
$188 those were the days. I remember you from The Nats even before I knew you were a member here.
They would have done themselves a huge favor if they had redesigned the rear quarter wheel opening. One of my car guy friends did just that and wow what an improvement. He raised the opening by cutting out all that rear quarter panel that covered the top of the rear wheel and had 1971 Mach one Mustang rear quarter partial panels welded in place. The front fenders were modified the same way to match. It really improved the look and stance of the first gen cars. Then he put bigger wheels and tires on. LOL
Lets face it, the early Stang was a pretty and cool looking car... upbeat Falcon!
I have had many Mopars over the decades but just one early Cuda, 65 273 2 bbl all done but sold it about 2016 before they got more popular and expensive sorta. LIke said, they look cool with the right size wheels.
And what's not to like about a early Dart or Valiant? Tires can make it.
