1966 Barracuda with factory disk: dual master conversion
Brakes for your Classic Mopar
  1. Kevin74
    Kevin74 Well-Known Member
    54
    19
    Oct 26, 2019
    Phoenix
    Local Time:
    6:17 PM
    Hey Guys,
    I have a 66 Formula S that already has factory disk brakes. I would like to upgrade my master cylinder to dual chamber. My question is what distribution port to use? The car already has a factory proportioning valve for the rear drums, so I just need a 5-port distribution block.
    My current distribution block is 4 port.
    1. Master cylinder line
    2. Left front line
    3. Right front line
    4 Rear drum line. (It gets split to left/right at the rear of the car)
    So I think I need a similar distribution block, but with two master cylinder input ports.
    Does anyone have a part number recommendation?
    Thanks!
  2. pishta
    pishta I know I'm right....
    20,088
    9416
    Oct 13, 2004
    Tustin, CA
    Local Time:
    6:17 PM
    67 dual mc for disk/drum, larger reservoir is used for disk side. Get any prop valve from a american SAE thread disk/drum car. I used a jeep one that will become your distribution block, or use 'dumb' 3 way block and a prop valve on drum side.
  3. Kevin74
    54
    19
    Oct 26, 2019
    Phoenix
    Local Time:
    6:17 PM
  4. Kevin74
    54
    19
    Oct 26, 2019
    Phoenix
    Local Time:
    6:17 PM
    Yes, I think I need a dumb(no proportioning) block with two inlets from MC, and 3 outlets. So this would be a 5 port distribution block.
    Does anyone have a part number for this?
  5. hemi71x
    hemi71x FABO Gold Member FABO Gold Member
    6,064
    2722
    Dec 22, 2009
    Rancho Cordova, CA
    Local Time:
    6:17 PM
    Find yourself a factory disc brake proportioning valve that was used on those cars.
    They are out there, but sometimes difficult to find when your looking for one.
    They are repoped, but it seems it's been hit or miss, if you get a good one or not.
    No, i don't have any more of them for sale.
    Long gone.
    • Like Like x 1
    • Dartsun
      Dartsun Mopar Dude
      2,109
      1872
      Feb 12, 2012
      Springfield Oregon
      Local Time:
      6:17 PM
      When I changed my master cylinder in my 65 Dart 2 pot master front Kelsey Hayes. I just ordered the distribution block and brake lines from inline tube. Fit perfect
    • Kevin74
      54
      19
      Oct 26, 2019
      Phoenix
      Local Time:
      6:17 PM
      Hi Dartsun,
      If you could share the distribution block part number from Inline Tube, that would be very appreciated. I went to their site, and I didn’t see what I think I need. I believe I need a distribution block with 5 ports: 2 for Master cylinder, 1 for rear brakes, 1 for left front, 1 for right front.
      Thanks!
    • Kevin74
      54
      19
      Oct 26, 2019
      Phoenix
      Local Time:
      6:17 PM
      Hey hemi71x,
      My car already has a factory proportioning valve in the rear brake line, since it was a factory disk/drum car.
      My hope is to replace my distribution block. Currently, it only has one input port since my master cylinder is a single. I would like to find one that accepts two inputs from a dual master cylinder.
      It’s also very possible that I misunderstand the braking system. From the looks of that photo, you know a heck of a lot more about brakes than I will ever know!
    • 66fyssh
      66fyssh Don't Stop Believin' FABO Gold Member
      6,280
      5788
      Jun 22, 2013
      Northwest GA
      Local Time:
      9:17 PM
      My 66 has factory Kelsey-Hayes. I did mine about 6 years ago with help from some FABO members.
      I used the original distribution block. Ran the back brakes through the proportioning valve and bypassed the distribution block.
      It's basically what @pishta recommended.
      At the top you can see where I removed the rear line , capped it at the block and connected it to the line from the proportioning valve.
      The bottom line runs to the driver's front. Next on the right runs to the back of the master cylinder. And top right runs over to the passenger front.
      Here's my m/c and Summit prop valve.
    • Dartsun
      Dartsun Mopar Dude
      2,109
      1872
      Feb 12, 2012
      Springfield Oregon
      Local Time:
      6:17 PM
      • Like Like x 1
      • Kevin74
        54
        19
        Oct 26, 2019
        Phoenix
        Local Time:
        6:17 PM
        Man, you’re the best! Excellent pictures and description. I’m going to copy that scheme exactly.
        • Like Like x 1
        • Kevin74
          54
          19
          Oct 26, 2019
          Phoenix
          Local Time:
          6:17 PM
