What do you use to connect the R5, J2, J2A and J3 wires where the Ballast used to be, when running a electronic ignition? I just have them ganged together with male and female spade connectors right now, the car came that way. Thanks
Are you using a pertronix?What do you use to connect the R5, J2, J2A and J3 wires where the Ballast used to be, when running a electronic ignition? I just have them ganged together with male and female spade connectors right now, the car came that way. Thanks
J2 is IGN 1, starter switch, R5 to IGN side of Reg. J2A, out of ballast to plus side of coil, J3 out of ballast to IGN 2 to starter switch. ThanksCan not tell much from the pic. Are referring to the original bulkhead positions when you say R5, J2, J2A etc?
You need to get the part number on that coil. Most people think "just cause" it's an MSD coil it needs no ballast resistor. That's not true. You need to make sure it's not for use with an external resistor. If it is, it should have one.
I run a Pertronix III today after many years of a Chrysler box. Still have the ballast for Original looks and wire connections but bypassed on the hidden side with solid 12Awg jumper. All Ignitions are not equal and to my knowledge all Chrysler boxes use a ballast. Coil choice may effect this as the last upgrade I did was long ago.
