[WANTED] 1966 Dart drivers side front and rear floor pans
Cars and Mopar Parts Wanted
Thread Status:
  1. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    15,855
    4929
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    4:03 PM
    Contact Seller
    As tittle says, I need good floor pans for the drivers front and rear on a 66 Dart 2dr Post.
  2. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    46,854
    31105
    Jan 18, 2006
    Iowa
    Local Time:
    3:03 PM
    • Thanks! Thanks! x 1
    • ch1ll
      ch1ll FABO Gold Member FABO Gold Member
      662
      210
      Jun 12, 2009
      Belgium,wi
      Local Time:
      3:03 PM
      while other year floor pans will work, 66 dart is one year only design. if you find extra floor pans, I need a full floor as well.
      • 69FBCuda
        69FBCuda Life in the Fast Lane
        2,085
        1113
        Aug 28, 2014
        Florida
        Local Time:
        4:03 PM
        • SGBARRACUDA
          15,855
          4929
          Dec 7, 2006
          Local Time:
          4:03 PM
          This is what I'm dealing with.
          • Like Like x 1
          • SGBARRACUDA
            15,855
            4929
            Dec 7, 2006
            Local Time:
            4:03 PM
            I may order new ones just figured I would see if somebody had some in their hoard.
          • toolmanmike
            46,854
            31105
            Jan 18, 2006
            Iowa
            Local Time:
            3:03 PM
            Nope. 66 has some "one year only" pieces like most years but the chassis and floor pans are universal between 63 and 66. Many of the body patch panels are the same for those years in the Dart line. Valiant is different.
          • ch1ll
            662
            210
            Jun 12, 2009
            Belgium,wi
            Local Time:
            3:03 PM
            not that I want an argument with you Mike, but the strengthening ribs in the 66 floor pan are different than the ribs in the repops. you can see this in Roy's picture and he has one solid side that if he took a picture of it you could really compare and tell. mine are totally rusted and I destroyed just enough of them where I would not be able to show you the difference. I believe the 63-65 are like the repops.
            I have also talked to guys that used a 67-69 full repop pan to replace their rusted 66 pan. those conversations with pictures of their work is posted in the 66 dart owners thread.
            • Like Like x 1
            • ch1ll
              662
              210
              Jun 12, 2009
              Belgium,wi
              Local Time:
              3:03 PM
              maybe you can tell the difference from one of my pictures,
              from my totally twinged dart. it is sitting level on the ground.
            • toolmanmike
              46,854
              31105
              Jan 18, 2006
              Iowa
              Local Time:
              3:03 PM
              Looks like the pan in your picture may not be an original. It should be white like the front sheet metal or is that what you were trying to show? I also see a couple inches of paint stripped above the seam as well.
            • toolmanmike
              46,854
              31105
              Jan 18, 2006
              Iowa
              Local Time:
              3:03 PM
              If by chance the Auto Body Specialties pans are slightly different for the 66's here's a fellow member that installed them with good results. See post #8. 66 dart floor pans
            • ch1ll
              662
              210
              Jun 12, 2009
              Belgium,wi
              Local Time:
              3:03 PM
              the floor pan is original, it was painted during its racing years. the floor just rotted out from a leaky windshield, the whole body is twinged. it sat quite a while after it was last raced. the guy was drag racing it with a 500+hp W2 motor yanking the skinnies with a 4.56 spool. it eventually blew off the drivers side frame connector which was not welded real well due in part that it had fenderwell headers and lacked structural bracing to make up for the lack of rigidity in the fender aprons with the holes cut in them for the headers.
              you are right aftermarket repop floor pans will work, but they are not quite the same as stock ones. you have to remember this year dart was the lighter designed version of the same looking car of previous years.
            • ch1ll
              662
              210
              Jun 12, 2009
              Belgium,wi
              Local Time:
              3:03 PM
              eventually I will have to relent and weld in what is available if I cannot find a 66 dart parts car with good floors, like next summer. I have been looking for at least 5 years now and they are like finding hens teeth.
              • Like Like x 1
              • toolmanmike
                46,854
                31105
                Jan 18, 2006
                Iowa
                Local Time:
                3:03 PM
                Here's some specs you might find interesting:
                Curb weight for Dodge Dart GT's:
                1963 2730#
                1964 2778#
                1965 2844#
                1966 2866#
                In 1967 they were heavier.
              • Ddaddy
                Ddaddy I'm changing the World... one pixel at a time! FABO Gold Member
                21,499
                27073
                Nov 7, 2015
                SW of Philly PA
                Local Time:
                4:03 PM
                • Like Like x 1
                Thread Status:
