1966 Plymouth Fury III New 446 Big Block built by Andy Jensen Engine made 520HP and 560ftlb on the dyno 440 HP block 30 over Forged Crank Ross Forged Pistons 10.5 to 1 Scat H-Beam Rods MP 284 / 528 solid lifter cam Coyle Adjustable Double Roller Timing Set 906 Iron Heads Port work done by Andy Jensen Larger Stainless Steel Valves Crower Springs and Retainers Crain Gold Roller Rockers with MP hold downs Edlebrock RPM Performer Intake 950 CFM custom build Pro Systems 4150 HP HP Manifolds with 2.5" full exhaust. Freshly rebuild 727 Part kickdown throttle body PTC 9.5" 3200-3500 stall converter 8.75 / 3.55 sure grip rear - Just serviced New Fuel tank and 3/8" SS pick up/ sending unit -6 Braided fuel lines and fittings from tank to carb. Aluminum Radiator with Shroud and Dual Electric Fans MP dual circuit master cylinder / Manual Brakes New 60 amp Alternator New Power Steering Pump and lines. B&M Trans cooler with -6 Braided Lines from the trans to the cooler. New Belts and Hoses Less then 400 miles on all parts. Plus so much more. . .. . .. . .. . .. . .. . .. . . Open to Trade of equal value. . .. . .Lets talk. $12500.00 obo
I almost for got... Motor now has Stealth Alum Heads with Comp Cam Springs and Retainers. Motor made 520hp and 560fttq with the iron 906 heads.
adding a video [ame="http://www.youtube.com/watch?v=n5NweB9PyhU"]1966 Plymouth Fury III 440 - YouTube[/ame]
Sorry .... Sold. It went to a guy outside Pittsburgh, PA. Its been 12.50s at 112mph. I wish i had not sold it.
