1966 valiant wheel and tire size question
Tires and Wheels (Mopar Hubcaps Too)
  1. TheGreatGazoo
    TheGreatGazoo Member
    20
    14
    Aug 14, 2019
    New York
    Local Time:
    4:10 PM
    So i have a 66 valiant with 4.5 bolt pattern and a 69 roadrunner that I want to change the wheel look on. I'm looking to move the wheels from the roadrunner to the valiant. The wheel size is 17X7. 0 offset. 4"backspace. Will the wheels (rims) size be ok. If so what tire size would you guys recommend
  2. cudamark
    cudamark FABO Gold Member FABO Gold Member
    8,921
    1416
    Mar 14, 2009
    San Diego
    Local Time:
    1:10 PM
    There's a few variables that might influence what will fit. Many times the rear axle wasn't centered in car from the factory, so, one side might have more clearance than the other. In a stock wheel well, I found with the stock wheel offset, I could put a 9" wide tire and a 28" diameter one without rubbing anything. It's pretty close though, so, take some measurements to verify. Custom wheels with odd offsets might allow something wider, but, you may run into problems in the front if you want all 4 wheels the same.
  3. toolmanmike
    toolmanmike Moderator Staff Member FABO Gold Member
    61,241
    49706
    Jan 18, 2006
    Iowa
    Local Time:
    3:10 PM
    First of all no 66 Valiant came with big bolt pattern. What rear end is in the car or what was modified on the original rear end? Either could have everything to do with what wheels fit.
  4. TheGreatGazoo
    20
    14
    Aug 14, 2019
    New York
    Local Time:
    4:10 PM
    Thanks
    The rear that is in there is a 8.75 that was made for my car. I was told it is the same dimensions as the old one just with large bolt pattern and 11 inch drums
