[FOR SALE] 1967 and earlier SB timing cover with timing tab
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
This timing cover is correct for small blocks 1967 thou it will work for earlier models also. This cover has the timing marks on a separate timing tab that bolts to the lower two water pump bolts on the passenger side. I cleaned and media blasted the cover inspect it for damage. Chase all the threads with a tap. Any hole that is not up to par I install a Heli-Coil insert. Includes the lower two water pump bolts. And is paint Chrysler Red. This is a hard to find timing cover. Mopar part number is 2128896 and is date coded 1967. $80.00 shipping included in the USA.
