1967 Barracuda heater contols?
Heating / Cooling / AC
  1. gm1236
    gm1236 Well-Known Member
    157
    64
    Aug 3, 2013
    Massachusetts
    Local Time:
    9:39 AM
    Are '67 Barracuda heater controls different than a '68. We have a '68 with a '67 dash and the heater controls don't fit right?
  2. RedFish
    RedFish Well-Known Member
    24,688
    3158
    Sep 5, 2007
    Local Time:
    9:39 AM
    Yes sir they are different. Even the length of those slots in the bezels are different.
    Wouldn't work right even if it did bolt up the same.
  3. Rocky_JS
    Rocky_JS 'cuda
    4,198
    156
    Feb 27, 2011
    Highland Maryland
    Local Time:
    6:39 AM
    heater box 67 and 68 are different also the defrost/floor cable is routed in reverse.
  4. gm1236
    157
    64
    Aug 3, 2013
    Massachusetts
    Local Time:
    9:39 AM
    Thanks guys, so to get this right we need to either change the heater controls and heater box to a '67 or get the right '68 dash for the car. But the mount for the heater control may be different and the '67 might not fit. Time to lose the heater!
    Thanks again.
  5. RedFish
    24,688
    3158
    Sep 5, 2007
    Local Time:
    9:39 AM
    A 68 dash would be the simple solution.
  6. Rocky_JS
    Rocky_JS 'cuda
    4,198
    156
    Feb 27, 2011
    Highland Maryland
    Local Time:
    6:39 AM
    Red, wouldn't he actually just need the metal part of the gauge cluster frame for a 68? The wiper switch alignment slot is slightly different from what I recall but will work, All else should work fine?
  7. RedFish
    24,688
    3158
    Sep 5, 2007
    Local Time:
    9:39 AM
    In either rally or standard panels the metal that supports the climate controller and the bezel are different.
    This is why while developing the D.I.N. friendly rally panel I had to buy one of every example. Only way to insure it would work in all applications.
    Took 4 tries to get this pic to upload then it went twice LOL
  8. mopar head
    mopar head Well-Known Member
    2,977
    758
    Oct 21, 2008
    Right here, can`t you see me?
    Local Time:
    9:39 AM
    This explains why my heater controls are bass-ackwards, on my 67.
    I`ve just been living with it, on=off, off=on. This blew my mind, could`nt figure what was going on and just gave up:thumblef:
  9. RedFish
    24,688
    3158
    Sep 5, 2007
    Local Time:
    9:39 AM
    OK waaaay down under the dash on the case is a little bracket where the cable sheathe is secured. If it is to the left of door lever and operates backward, simply relocate it equal distance right of the door lever.
  10. airwoofer
    airwoofer Drivetrain limit explorer
    2,208
    39
    Jan 4, 2011
    Huntsville, AL
    Local Time:
    8:39 AM
    Wonderful. While I am in the process of bringing my 68 drag fish back to street I bought a 67 cause it had a nice interior. I was gonna use the 67 heater box and buy a 68 bezel. Looks like it isn't that simple.
  11. RedFish
    24,688
    3158
    Sep 5, 2007
    Local Time:
    9:39 AM
    DeMonDIN rally panel mod solves all these problems. I'm just days away from backlighting the A-body rally bezels too. First 3 prototype kits are in customers hands. :)
