1967 barracuda vent window channel
clementine
Flight risk
Emerald city
Happy Sunday!
Any idea where to source this vent window channel piece? Is it a 'W' shaped plastic jobby with felt sprayed on it?
Thanks FABO!!
Not 100% sure but I think it's the same PN used on ram vans and pickups thru 1993. Its cut to length. You may have to do a little research on this one.
Thanks. A bit spendy on that. I wonder if there is a cut to length dimensional situation. Ill start measuring and let you know what I find.
Not cheap. the MP part was 55 per door 18 years ago. While the kits were not available a member here used the felt side of adhesive back velcro folded around glass edge. I dont think the plastic guides alone are available although they once were, at ebay, etc... Good luck
