1967 barracuda windshield trim help
Mopar Body and Trim
  1. RogerCox
    RogerCox Well-Known Member
    129
    22
    Sep 30, 2020
    Visalia Ca
    Local Time:
    3:21 AM
  2. 4spdragtop
    4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
    32,446
    13556
    Aug 28, 2009
    Wasting time here
    Local Time:
    5:21 AM
    Yes 67 cuda has "mylar lockstrip" pricey and a shitty 1 year design(we have a 67).
    Changing to 68/9 is a wise choice.
    BUT pricey. Go with a "Precision" 68/9 gasket. Pay the $$.
    So gasket, clips, stainless trim.
    @69FBCuda has trim for sale.
    @RPM440+6 is a good member here and a distributor. He can hook you up with gasket/clips.
    Dont get sucked in with cheaper parts for this. Use a quality gasket(Precision). Like I said rpm440+6 will give you the straight goods.
    • Thanks! Thanks! x 1
    • RogerCox
      129
      22
      Sep 30, 2020
      Visalia Ca
      Local Time:
      3:21 AM
      Perfect thank you!! Is there any metal trim options for the rear window? I have a notchback
      • Like Like x 1
      • 4spdragtop
        32,446
        13556
        Aug 28, 2009
        Wasting time here
        Local Time:
        5:21 AM
        No problem Roger, glad to help. Ibelieve same scenario for rear trim. BUT there is no aftermarket notchback stainless trim. Probably have to find used and that stuff is pricey!
        • Agree Agree x 1
        • RPM440+6
          RPM440+6 FABO Vendor FABO Vendor
          299
          198
          Dec 1, 2013
          Georgia
          Local Time:
          6:21 AM
          For the '67 A-Body applications with the correct mylar insert, you will want to purchase a Precision WCR D690 B gasket. The mylar insert is purchased separately and the number is WSL 690 B. If you should decide to go with the gasket for the stainless trim, the Precision gasket is WCR D690. The only gasket available for the notchback application is the style that uses the stainless trim as found on the 68 and 69 applications. The Precision part number is WCR DB4076.
          Precision is the only manufacturer of the correct mylar inserts. It is a rigid piece and not a flexible lock bead as used on other applications. Some guys have used the flexible style with mixed results. The mylar insert for the fastback rear window is back available again. We had one customer who bought this insert in the hopes of modifying it to fit his notchback application, but I have no ideal on how it turned out.
          As for the Precision gaskets in general, we have sold hundreds of the WCR D690 and WCR DAB4076 and have to say that the quality is very good. Most of the issues have been with incorrect installation procedures.
          @RogerCox , I will send you a message.
          • Like Like x 1
          • RedFish
            RedFish Well-Known Member
            25,019
            3717
            Sep 5, 2007
            Local Time:
            6:21 AM
            Rear window stainless reveal from a 68 or 69 donor is rarely available and sells for 300 to 500. I bought a incomplete set and waited years for the one missing piece to come to me. Staying with the 67 type may be the best plan. Good luck
            p.s. I like the red piping in the seat covers.
          • Mattax
            Mattax Just the facts, ma'am FABO Gold Member
            12,821
            8543
            Feb 7, 2013
            Phila. Pa
            Local Time:
            6:21 AM
            If you want to stay with the '67 lockstrip for the rear you can buy them from YO and probably other venders. Then gently heat and shape the ones for the curved section. Hair dryer or heat gun with low heat settings and lots of patience. I did it years ago and got one perfect, broke the other. Fortunately I found an NOS one at Englishtown swap meet, saving me the neccesity of buying another set and making another attempt. I bought the repop from Mitchell's - yea - the Frank Mitchell because he was the first and for a while only vender with the correct lockstrip.
          • RogerCox
            129
            22
            Sep 30, 2020
            Visalia Ca
            Local Time:
            3:21 AM
            I want to have the front and rear window like this.
            Can someone message me who sells exactly what I need to do this, looks great!
            Thanks
          • 4spdragtop
            32,446
            13556
            Aug 28, 2009
            Wasting time here
            Local Time:
            5:21 AM
          • RogerCox
            129
            22
            Sep 30, 2020
            Visalia Ca
            Local Time:
            3:21 AM
            Also anyone have a link to the bumper guards from that video, can’t find those either ‍♂️
          • RedFish
            25,019
            3717
            Sep 5, 2007
            Local Time:
            6:21 AM
            I dont know if the bumper guards are reproduced. Parts wanted post Might get you some used ones. You need to drill holes in the bumpers to add them. OEM had drawing/instructions/measurements in the box. You can put the front ones at bumper bolts. Rear ones will land right in front of reverse lamps of 67 and 69 if mounted at bumper bolts.
