ryan1964
Looking to see if anyone has a 440 4speed 1967 barracuda and what are you running for exhaust manifolds thanks
Ok I'll look into that thanksSo the challenge with any A body BB with four speed is that most headers are in the same space as your clutch linkage.
I have gone headers as well as original A body manifolds. Most will recommend either the tri-y from Schumacher or the TTI headers. But to use those on a manual BB, you are best off using a hydraulic clutch.
not trying to cut into the carthe clutch linkage clears fenderwell headers fine, just saying![]()
Beautiful car thank youBe the same factory manifolds with a 440 as my Wife's 383 Formula S..
View attachment 1716361447View attachment 1716361448View attachment 1716361449
i know everyone hates it when someone cuts the inner fenders but who's car is it anyway? if it gets the car on the road to enjoy and you're happy that's the most important thing surely. if someone buys it in years to come and want it stock then 'it's only metal' and can be put back.And I didn’t even think about the fenderwell headers.
Yesi know everyone hates it when someone cuts the inner fenders but who's car is it anyway? if it gets the car on the road to enjoy and you're happy that's the most important thing surely. if someone buys it in years to come and want it stock then 'it's only metal' and can be put back.
neil.
i made the fenderwell headers for the 440 i put in my old 65 dart and plugs were easy to change. reach under the headers from the front and you can get them all. hydraulic clutch is great if you have an external slave cylinder. those poxy hydraulic release bearings suck big time! even on oem stuff (which seems to use them across the board) the seals fail quite often. then the trans has to come out just for a bloody hydraulic seal, what a ball ache!.Fenderwell headers suck, period. Hydraulic clutch? Thousand dollars plus.
Sorry, you couldn't pay me to change the spark plugs on a big block in an A Body. I love my small block stroker.
Exactly how mine were done. (above posted) Schumacher did mine.For the DIY person.................
Modified Schumacher Headers for 4-Speed
Here are the pictures I took while modifying my Schumachers to fit a 4-speed. They still go in with the engine in place. It was easy. I will be installing my new exhaust this weekend. Rodwww.forabodiesonly.com
Awesome thank youExactly how mine were done. (above posted) Schumacher did mine.
