[SOLD] 1967 Plymouth Valiant
Mopar Automobiles For Sale
Thread Status:
  1. 71valiant
    71valiant Make fast, break, repeat.
    768
    28
    Jul 21, 2004
    Columbus, Indiana
    Local Time:
    8:54 PM
    Contact Seller
    67 Valiant. 360 .30 over. Ross forged pistons, Eagle rods, 10:2 compression. Mopar steel crank. Mopar 528 solid cam, Edelbrock RPM intake, Demon 750. EQ heads. Maybe 300 miles on engine. 8.75 rear with 3.90 gears, cone sure-grip, 489 case. 727, 3800 PTC stall. Hellwig front and rear sway bars. Minitub with narrowed rear. Running 295's right now. New rear brakes and hardware. Tons of stuff done to it. I just put a new fuel setup on it. If serious please pm me and I can go into more detail.
    12500.00
    • Like Like x 5
    • mopowers
      mopowers Well-Known Member
      5,206
      2261
      Feb 15, 2006
      West Sacramento, CA
      Local Time:
      5:54 PM
      Just curious- what's it painted with?
    • 71valiant
      768
      28
      Jul 21, 2004
      Columbus, Indiana
      Local Time:
      8:54 PM
      It was like this when I got it. I'm not a paint guy, but I think its primer black.
    • 71valiant
      768
      28
      Jul 21, 2004
      Columbus, Indiana
      Local Time:
      8:54 PM
      Here's a few more pics of the engine and the trunk fuel setup.
    • Alex5280
      Alex5280 74' Duster
      1,290
      1061
      Jun 3, 2015
      Broomfield, Colorado
      Local Time:
      6:54 PM
      Is this still for sale?
    • demon joe
      demon joe Member
      22
      0
      Oct 16, 2009
      NJ
      Local Time:
      7:54 PM
      PM sent
    • 71valiant
      768
      28
      Jul 21, 2004
      Columbus, Indiana
      Local Time:
      8:54 PM
      It is.
    • 71valiant
      768
      28
      Jul 21, 2004
      Columbus, Indiana
      Local Time:
      8:54 PM
      Replied
    • 68HAVOK
      68HAVOK Well-Known Member
      126
      72
      May 31, 2016
      Modesto
      Local Time:
      5:54 PM
      Are those post windows rolled down?!
    • 71valiant
      768
      28
      Jul 21, 2004
      Columbus, Indiana
      Local Time:
      8:54 PM
      Yup
      • Like Like x 1
      • cuda620
        cuda620 Well-Known Member
        1,630
        148
        Oct 26, 2014
        indiana
        Local Time:
        7:54 PM
        Has it been mini tubbed? Big back tires. Not complaining,just curious.
      • 71valiant
        768
        28
        Jul 21, 2004
        Columbus, Indiana
        Local Time:
        8:54 PM
        It does have a mini tub. Running 295's out back.
        • Like Like x 1
        • Alex5280
          Alex5280 74' Duster
          1,290
          1061
          Jun 3, 2015
          Local Time:
          6:54 PM
          Did your car sell? Or is it still for sale?
        • 71valiant
          768
          28
          Jul 21, 2004
          Columbus, Indiana
          Local Time:
          8:54 PM
          I haven't spoke with the gentleman I was in the trade with for a couple of weeks. I'm assuming the trade has fallen through. So it's back up for sale I guess.
        • 71valiant
          768
          28
          Jul 21, 2004
          Columbus, Indiana
          Local Time:
          8:54 PM
          12,000
        • 71valiant
          768
          28
          Jul 21, 2004
          Columbus, Indiana
          Local Time:
          8:54 PM
          Heres engine specs.
          Edelbrock Performer RPM intake manifold #7176
          Engine Quest magnum cylinder heads, 62cc closed combustion chambers
          10:2 compression ratio
          2.02/1.60 Scorpion stainless steel intake/exhaust valves
          Comp Cam beehive valve springs
          Comp Cam rocker arm studs #4504-16, ARP polylocks #300-8241
          Comp Cam 1.6 ratio adjustable rocker arms with roller tips #1416-16
          Comp Cam pushrods
          Felpro gasket set with Q1008 head gaskets
          Mopar LA 360 engine block bored .030 over
          Ross flat top forged pistons with full floating wrist pins #99627
          Piston top .004 below deck, piston to cylinder head quench clearance .043 inch
          Sealed Power moly piston rings
          Eagle SIR forged steel connecting rods with ARP rod bolts #6123CB
          Mopar cast iron crankshaft, external balanced with Mopar front damper
          Standard sized tri-metal main and rod bearings
          ARP crankshaft main bearing bolts #140-5001
          ARP cylinder head bolts #144-3602
          Mopar .528 Solid Cam and lifter set
          Engine Pro double roller timing chain and gear set with 9 keyway adjustment
          Mopar magnum timing chain guide set
          Melling high volume oil pump, pickup tube, and drive #M72HV, 72-S2,IS-72
          Kevko 6 quart oil pan with internal baffles #M302, M301-1
        • moparguy1967
          moparguy1967 Well-Known Member
          212
          0
          Dec 21, 2009
          Local Time:
          8:54 PM
          Any video of it running ?
        • 71valiant
          768
          28
          Jul 21, 2004
          Columbus, Indiana
          Local Time:
          8:54 PM
          I can get a clip of it running..
        • 71valiant
          768
          28
          Jul 21, 2004
          Columbus, Indiana
          Local Time:
          8:54 PM
          Just ran out and fired it up for the first time in maybe two months.
          • Like Like x 2
          • SMOKEY
            SMOKEY Well-Known Member
            248
            19
            Sep 30, 2005
            florida
            Local Time:
            8:54 PM
            got to have a ph# to call you.smokey.
          • 71valiant
            768
            28
            Jul 21, 2004
            Columbus, Indiana
            Local Time:
            8:54 PM
            I'll send it to you in a private message.
          • 71valiant
            768
            28
            Jul 21, 2004
            Columbus, Indiana
            Local Time:
            8:54 PM
            SOLD
          Thread Status:
