[FOR SALE] 1968 A-body 383 block and front left motor mount bracket. $500.00 plus shipping
Mopar Mechanical Parts For Sale
Thread Status:
  1. tdemo43
    tdemo43 tdemo43
    187
    25
    Mar 20, 2007
    Idaho Falls, Idaho, 83402
    Local Time:
    2:25 AM
    Contact Seller
    1968 Std. Block .cast date 3 /1/68 . Factory mount bracket $500.00 plus shipping IMG_20180318_190800.jpg IMG_20180318_124311.jpg IMG_20180318_124311.jpg IMG_20180318_124311.jpg IMG_20180318_124311.jpg
  2. 1969383S
    1969383S FABO Gold Member FABO Gold Member
    5,665
    2664
    Jan 8, 2012
    Cumming, GA.
    Local Time:
    4:25 AM
    Not that I am interested but is there a SO number stamped on the the top of the bellhousing mount area on top on the right side of the block behind the right head. Someone might be looking for a numbers engine.
    • Agree Agree x 1
    • tdemo43
      tdemo43 tdemo43
      187
      25
      Mar 20, 2007
      Local Time:
      2:25 AM
      Let's clear this up now!! I have looked for number behind the driver's head on the lip that mounts the bellhousing, also on pass side, the pad located above pan rail at bottom of block, pad below the dist mount, all to no help. On the pad below the dist mount is stanped D 383 then farther down the letter R is stamped. Could this be a replacement or service block?? This block is std. now with no gouges or deep pits. I want it to end up in a-body.
      • Like Like x 2
      • a12
        a12 Well-Known Member
        196
        162
        Nov 19, 2014
        maryland
        Local Time:
        3:25 AM
        If I'm not mistaken,In 1968 .If it had numbers on it,they'd be where the engine and trans meet on the top
      • Mopar Tim
        Mopar Tim FABO Gold Member FABO Gold Member
        19,872
        12600
        Nov 29, 2014
        vista CA.
        Local Time:
        1:25 AM
        I think , with this info, it was a replacement engine. Warranty. The "R"
      • blewbyu
        blewbyu FABO Gold Member FABO Gold Member
        2,248
        519
        Jul 14, 2010
        Florida
        Local Time:
        3:25 AM
        PM sent and have not heard a thing
      • tdemo43
        tdemo43 tdemo43
        187
        25
        Mar 20, 2007
        Local Time:
        2:25 AM
        Just got back in town, I have looked high and low for a vin on this block and found nothing. I got this in a pile of mopar parts the guy had collected for years. I'm going to answer all inquires asap. I've been gone to see family in Utah.
      • 340man
        340man Well Known Member FABO Gold Member
        1,152
        96
        Jan 2, 2006
        Gig Harbor,Wa.
        Local Time:
        1:25 AM
        Interested in block for my 67 Dart GTS car, if still available....
      • tdemo43
        tdemo43 tdemo43
        187
        25
        Mar 20, 2007
        Local Time:
        2:25 AM
        The block and bracket are for sale to the first cash buyer. I could trade for sure-grip, with 3:91 gears. Will crate and drop off at fastenal,, or shipper of your choice, possible delivery to L.A. area, so cal, Vegas, Utah, Montana, so Idaho. Have semi-driver goes to Ca. weekly. I'd like to see it in a-body. Let's talk.
      • BB-Dave
        BB-Dave Legandary Member Legendary Member
        1,512
        88
        Jun 9, 2010
        North East
        Local Time:
        4:25 AM
        Just because this came out of an A-body doesn't mean it's a "factory installed style/type" A-body block. Your pics show this. Any 383 will fit in an A-body.
        Must be an over the counter 383 block replacement for any style body (no VIN).
        Surprised davescuda hasn't elaborated on this???
        Not sure why your hung up on this going into an A-body? Just sell it for the first $$$$
      • tdemo43
        tdemo43 tdemo43
        187
        25
        Mar 20, 2007
        Local Time:
        2:25 AM
        Thanks for the info!! I didn't know all 383 blocks had the drilled 2 bosses on driver's side front of block. I'm sure Shumacher or some one makes a adapter motor mount to put b-block in a-body k-frame, I have the bracket to make it like factory big block car. Thanks again.
      • Peter Pesaturo
        Peter Pesaturo Active Member
        29
        2
        Dec 28, 2017
        Florida
        Local Time:
        4:25 AM
        If my memory is correct, you are correct that all 383 blocks were not drilled and tapped for the A body mount just like all 440 blocks, although different than the 383 were not drilled and tapped for A body mounts
      • davescuda
        davescuda FABO Gold Member FABO Gold Member
        9,993
        1523
        Apr 30, 2007
        Cheshire, CT
        Local Time:
        3:25 AM
        This is not a factory A body block but will work in an A body. I have a body 383 motors
      • BB-Dave
        1,512
        88
        Jun 9, 2010
        North East
        Local Time:
        4:25 AM
        Those tapped holes could be used for other accessories such as power steering? Anybody could have drilled and tapped those holes. I have a '69 440 block that has the tapped holes above the oil filter which is where a 440 A-body motor mount is mounted......that doesn't mean it's a factory 440 A-body motor..........
        There is one distinct fact that all factory 383 A-body blocks had machined off the block from the factory which the pics show is not.
      • davescuda
        9,993
        1523
        Apr 30, 2007
        Cheshire, CT
        Local Time:
        3:25 AM
        C Body 383 are also drilled they also have the same bracket.
        • Agree Agree x 2
        • Like Like x 1
        • moparmat2000
          moparmat2000 FABO Gold Member FABO Gold Member
          16,402
          5534
          May 13, 2010
          Grand Tetons
          Local Time:
          3:25 AM
          Warranty block is perfect for somebody needing one for a factory 383 car that was cast after their build date if their car doesnt have one. Its not as desirable as a numbers matching block, but since these things were driven hard i am sure some of em went pop and had warranty engines installled with the corporate 5-50 warranty of the time.
        • davescuda
          9,993
          1523
          Apr 30, 2007
          Cheshire, CT
          Local Time:
          3:25 AM
          The R does not mean warranty block, it means regular fuel. I think S is warranty
        • 1969383S
          5,665
          2664
          Jan 8, 2012
          Cumming, GA.
          Local Time:
          4:25 AM
          S is special in 69 and Orange so I believe that is A-body , not sure about 68 maybe they were similar. R seemed to carry over as regular fuel 2barrell low compression. So I would guess C-body block.
          • Like Like x 1
          • 1969383S
            5,665
            2664
            Jan 8, 2012
            Cumming, GA.
            Local Time:
            4:25 AM
            Always thought warranty had a tag with a screw type rivet attached near the front right side core plug.
          • 1969383S
            5,665
            2664
            Jan 8, 2012
            Cumming, GA.
            Local Time:
            4:25 AM
            68 specific
          • pomonamissel
            pomonamissel Well-Known Member
            1,863
            899
            May 21, 2015
            san jose , ca
            Local Time:
            3:25 AM
            man thats pricy for a 65 c body b or rb motor drivers side bracket . there the same .
          • tdemo43
            tdemo43 tdemo43
            187
            25
            Mar 20, 2007
            Local Time:
            2:25 AM
            I don't claim to know everything about a-bodys, I haven't seen any c-bodies with that mount bracket installed on the tapped holes. To be fair I'll sell for best cash offer, if not I'll stash it for use in a 68 valiant 2dr. post. Thanks again for all the info.
          • pomonamissel
            1,863
            899
            May 21, 2015
            san jose , ca
            Local Time:
            3:25 AM
            do you have the big block k member as well ? its required to use that bracket on the drivers side engine mount . thats 65 c body with 361 383 b or 413 426 rb engines only .
          • tdemo43
            tdemo43 tdemo43
            187
            25
            Mar 20, 2007
            Local Time:
            2:25 AM
            WOW!! so every 65 c-body uses that bracket and all 65 B and RB blocks are cast with those 2 mount/threaded bosses. If they were installed in a c-body. I don't normally take the k-frame out of any c-bodies, I mainly use the imperial frame pieces. I don't have any 65 k-frames. I just don't remember c-bodies with that bracket. When I get some time I'll go look at my friend's yard for c-bodies that use that bracket, and 65 blocks with threaded bosses on driver's side front. I'll post my findings later.
            • Like Like x 1
            • Peter Pesaturo
              29
              2
              Dec 28, 2017
              Florida
              Local Time:
              4:25 AM
              I never said only A body engined were drilled. I said not all 383 blocks were drilled. As a matter of fact the 440 in my 69 1/2 A12 Road Runner is drilled and tapped for the A body mount.
            Thread Status:
