1968 Dart 2dr sedan
Dukeboy
Member
Va
Rating - 0%
0   0   0
For Sale: 1968 Dodge Dart, 2dr sedan. Body in primer, but may need quarters. Looks "ok" Now. 440 Big block, 727 Auto with 3500 Stall, 8 3/4 rearend, narrowed, with 3.91 Sure Grip (741 case). 295/50/15" Hoosier rear tires brand new. New front tires on 3 1/2" Centerline wheels. Ran High 6's On Nitrous 8 th mile. Street driven. Dominator Holley carb on Team G intake. Solid lift Comp Cam (.562 lift 265 Dur. @ .050). "915" heads Extensively ported with 2.08 1.88 Exhaust valves. Bored .030. Flat tops.
Fuel cell in trunk as is battery. 8 point Roll cage. Needs inner wheel tub work. Springs moved inward. Custom Steel cowl hood. $13,000.00
Car is located in Appomattox Va.
So, is that a self morphing grille you have on there. You can be a '68 on one day then a '69 on the next? All kidding aside, good luck with the sale.
Actually, those pics are quite old. I had a '69 Front end on it, but decided to put it back a '68.
Thanks.
is there still a full Interior in it ? pics ?
No. Interior has one front driver's bucket seat. Have the other bucket for pass. side. Full 8 point cage. No back seat. Fuel cell in trunk.
Can get pictures if needed. No carpet. Has a little rust through on pass. side floor pan, but i have a factory floor pan i cut out of another car that goes with.
