[SOLD] 1968 Dodge Charger Bullitt tribute
Mopar Automobiles For Sale
Thread Status:
  1. fnabody
    fnabody Well-Known Member
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    Contact Seller
    I have decided to try and sell my 1968 Dodge Charger Bullitt tribute car. Why? The truth and honest answer to that is that another Mopar that has grabbed my interest has come up for sale and the only way I can afford to purchase that car is to sell mine. I'm in the position of not having to sell my car, I just want to put it out there and see what happens. If the car I want to buy sells before I sell my car then my car is immediately off the market and not for sale. I have all the reciepts for the parts bought and work done to the car. I will do my best to describe my car below. I'm sure I'll miss a few things because alot has been done to this car over the last three years. There are a few members who have seen my Charger and I can give you their names if you need an opinion other than mine. In my opinion I believe my car is not a museum piece. It is a very nice above average driver. Cost wasn't a factor when I built this car because it was built with the intention of never selling it, it wasn't and isn't an investment. That is because this is the last Mopar I will ever restore and I built it with the equipment I wanted. If I was able to order this car back in 1968 this is how I would have ordered it with the exception of possibly a 426 Hemi.
    BODY: The car has had both rear quarters replaced with full quarters from AMD. The car has also had a new one piece trunk pan also from AMD installed. The rest of the sheetmetal is original Chrysler sheetmetal. The body was professionally prepped and painted in base/clear. The body is laser staright! The bodyman that did the work has been in the restoration business for nearly 40 years. If there are any questions that I can't answer about any of that work I can set up a meeting or telephone call with the bodyman.
    OUTER BODY: The front and rear bumpers are new from Goodmark. The front grill trim is new from Gunslinger. The vinyl top checkmark trim is new from Gunslinger. The vinyl top is new from Legendary. The tail light assemblies and pot metal tail trim are all new from BEA Parts. The radio antenna is new from Metro. The door handles and mirrors are new. The roof drip rail stainless is new reproduction. The rear window trim is poilished. The trim on the the top of the doors and top of the rear quarters is polished. The windshield trim is original and not polished. The wiper arms and blades are restored to original condition. The hood turn signal lenses are new from Charger Specialties. The wheel well opening moldings are the originals and are real nice. The gas cap and trim ring are new reproduction parts. The front turn signal lenses are new from Goodmark. The rear plate light lens is new. All the glass is tinted and is all new from AMD. All the emblems are original NOS Chrysler parts.
    UNDER HOOD AND TRUNK: The trunk has the original jack assembly, spare tire, correct hold down, and a new heavy duty rubber herringbone trunk mat. Under the hood there is a recored 043 radiator with a three core used instead of a 2 core. The radiator also has a correct 2 piece steel shroud. There is an electronic voltage regulator housed inside of an original looking points type housing. There is a gel cell group 27 reproduction battery. The engine sports a Chrysler electronic ignition conversion kit with the box semi hidden on a custom bracket that is mounted to the rear intake vally pan sealing rail.The vacuum hoses for the headlight assemblies are new. The engine is completely dressed and painted as a correct vintage 1968 H.P. 440. The headlight, engine, and rear harnesses are all new M&H harneses from Year One. The alternator is a restored 1968 unit. The carb is a correct numbered Carter AVS 4 speed carb that was concours restored by Scott Smith from Harms Automotive. The original three speed wiper motor was restored by jules the Wiperman. The plug wires are firewires and the correct 1968 ignition wire bracket kit was used to route the wiires. The intake manifold, waterpump housing and H.P. exhaust manifolds are correct .vintage 68 casting numbers.
    DRIVETRAIN: The car has a completely rebuilt 1971 440. This engine was in excellent condition before the rebuildand still retains its stock bore. The 906 heads have been treated to a post clean up three angle valve job, quality bronze guides, new springs and valves, cut and all chambers cc'd. The cam is a stock Mopar 440 magnum restoration cam. The windage tray has a few custom mods along with a few other oiling mods. The pan is a 6 qt with filter pan. The exhaust system is by Gardner Exhaust. It includes an H-pipe, hemi style mufflers, tail pipes with original style chrome tips. It isn't too loud and is a pleasure to drive. The transmission is a 1968 vintage 18 spline hemi four speed that has been completely rebuilt and mated to a correctly centered stock numbered casting bellhousing. The driveshaft is new. The rear is a 1969 vintage Chrysler 3:54 dana 60 that has been completely rebuilt. All of this mechanical work was performed by Bob at Outrageously Vintage, a Mopar only machine shop with decades of expirience. Again, it there are any questions I can't answer I can set up a meeting or phone call with Bob. Check them out at www.outrageouslyvinatge.com.
    OTHER: The fuel tank, tank straps, sending unit, fuel lines, vapor seprator, fuel filter and the rubber lines are all new.
    The brake lines are all new from Fine Lines. The car has 11 inch power drum brakes all around. The rear brakes have new wheel cylinders, shoes, and hardware. All the 11 inch brake drums were removed from a 1969 Dodge Coronet with 31,000 miles and are mint!
    SUSPENSION: All four ball joints are new, all 4 tie rod ends are new, upper and lower control arm bushings are new, idler arm is new, strut rod bushings are new, all 4 shocks are new. The torsion bars are the correct heavy duty 440/hemi bars. The rear leaf springs are new 1 inch over stock Hemi style springs from Espo's springs and things. The shackles have all new bushings. The front k-frame has the correct hemi skid plate installed.
    INTERIOR: The headiner, front bucket/rear seat burlap, foam, covers, and door panels are all new Legendary parts. The carpet, rear package tray, rear seat divider panel are all new from trim parts. The upper front and rear pads, all dash pads are original black Chrysler parts in excellent condition. The armreat bases are new from PG Classics. The window handles are new. The console body is new from Tonys Parts. The 4 speed console top is new from PG Classics. The glovebox liner, glovebox lens, map light lens are all new. The rallye guage cluster with the tic toc tach has been totally retored by instrument specialties. The guage faces were retored by their silk screening process, no decals and they are beautiful. All the dash plastic is new from BEA parts. The seat belts are all re-webbed with the correct material and even have the correct date code tags sewn on.
    As you can see, I probably spent more than I should have. I know people that haven't spent as much as I have on a matching numbers car. Cost wasn't a factor because it was never my intention to sell this car. I built it to my liking. I like original looking cars and love all the little but correct details. Again, this car was built to be driven so I had to draw the line somewhere. There is still room to improve this car and take it to the next level. There are still a few small issues that need attention and those will be disclosed and dicussed in detail with a serious buyer. These are small issues that anyone with a little mechanical ability can take care of. That's half the fun of these olf Mopars, loving them with your wrenches. The car has just under 600 miles on it since completion. If you've read what I've written than you can figure I've spent foolish money on this car, but it is now a nearly new car. I have a small Mopar restoration parts business that I just went full time with. I'm very busy as we are only a few weeks away from launching our own website so my time is very precious right now. Not to give off any bad vibes I ask that only serious buyers inquire. I just don't have the time to just shoot the breeze. I apologize and wish I could but again time is working against me right now. I will do my best to comunicate and accomodate/answer any questions or concerns with potential but serious buyers. The best way to reach me is to PM me here and we can go from there. Price 30K. I'm open to offers and have a little wiggle room but they must be realistic and reasonable. I'm easy to get along with but on the same note, I'm not willing to take a beating, sorry. You guys and gals all know what he parts and restoration costs are. I havent included one hour of the time I've spent working on the car because that is a labor of love. The price reflects the cost of the car, the parts, and the body and paint work. Like I stated at the beginning of this ad, I don't have to sell, I want to sell but only if I can purchase the other car that is up for sale. The worse that can happen is that I'm stuck with a beautiful 1968 triple black Charger, and that's not a bad thing
    Thanks FABO for the ad!
    [​IMG]
    [​IMG]
  2. bamacuda
    bamacuda Well-Known Member
    2,159
    69
    Jan 2, 2007
    Hoover, Alabama
    Local Time:
    7:04 PM
    Wow!
  3. fnabody
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    Supposedly my Charger came from Alabama but I personally don't have any proof of this, it just what I was told by a previous owner.
    [​IMG]
  4. fnabody
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    [​IMG]
  5. fnabody
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    [​IMG]
  6. fnabody
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    [​IMG]
  7. casey70dartreed
    casey70dartreed Well-Known Member
    263
    1
    Apr 6, 2009
    Ravensdale/Ellensburg WA
    Local Time:
    5:04 PM
    Gorgeous Gorgeous car!!!! Best of luck!
  8. fnabody
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    [​IMG]
  9. fnabody
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    [​IMG]
  10. fnabody
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    Thanks. I can't lose no matter what happens, other than not getting a HEMI car. If it's meant to be it will happen. If not I guess I'm stuck with my old Charger!
  11. Blownfish
    Blownfish Well-Known Member
    1,044
    7
    May 26, 2009
    St.Louis
    Local Time:
    7:04 PM
    I couldn't think of a better car to be stuck with. I've had 4 69's, a 68, a 70 and a 73, and I so regret selling my original 69. We'd be talking if I had the garage space.
    One of the original Bullet cars was just recently found in Tuscon, the other was destroyed in the explosion scene.
  12. kikgas01
    kikgas01 Well-Known Member
    533
    0
    Oct 10, 2009
    Iowa
    Local Time:
    7:04 PM
    No it wasn`t. Watch the movie. It cruises behind the station when it explodes.8)
  13. 1967DartGT
    1967DartGT Well-Known Member
    844
    1
    May 28, 2008
    Livingston, MT
    Local Time:
    6:04 PM
    My second car was a black 68 Charger. Your car looks awesome!
  14. fnabody
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    Thanks for the compliment. Any links to that story about the original Bullitt being found in Tucson? I have a friend who lives there.
  15. stevedemon340
    stevedemon340 Senior Member
    367
    2
    Jan 2, 2010
    Poplar Bluff Mo.
    Local Time:
    7:04 PM
    Beautiful '68.
  16. Wylde1
    Wylde1 "No Value Added" Member
    2,329
    8
    Sep 1, 2008
    Ottawa, Ontario, Canada
    Local Time:
    8:04 PM
    If you want a HEMI car, you could drop a crate HEMI in that gorgeous, sweet, slick, black Charger. Ya, that's the stuff!
    Wylde1.
  17. Blownfish
    1,044
    7
    May 26, 2009
    St.Louis
    Local Time:
    7:04 PM
    They had bought two cars for the movie, a blue standard charger and a yellow R/T, they were both painted up black and made to look the same. The "blue" car was the one they used for all the bad stunts (wrecks) and the car they used in the gas station explosion, which from what I read was not part of the original script. The "yellow" car was the car they bolted the cameras to and used in most of the car chase scenes and the car that got sold to a local dealership after filming, which repainted it back to yellow and sold it.
    There were a few stories written about it, I think MCG had the best coverage of it. The guy that has it didn't know what it was when he bought it, they started to strip the car down to restore it and found holes drilled everywhere. He supposedly had a friend that worked with movie cars and knew what the holes were for so he did some research and made some calls and come up with the original info when they originally purchased the two cars for the movie and a lot of behind the scene photos of the car with the cameras mounted to it. I'll look around and see what month/year it was in MCG
    My uncle still has a house in Tucson, it turns out the guy that has the car was a friend of his and did the upolstry in one of his old Mercs.
  18. Tony Fields
    Tony Fields That's How I Roll Legendary Member
    8,671
    364
    Aug 8, 2006
    Columbus, Indiana 47201
    Local Time:
    8:04 PM
    Gotta love "Triple Black"!
  19. MOBodyman
    MOBodyman Well-Known Member
    1,869
    50
    Jun 14, 2005
    South Central MO
    Local Time:
    7:04 PM
    Wow! That is one beautiful car! I applaud your attention to detail. :cheers: I've accumulated 15+ old car/restoration projects, at least that many parts cars, and a truck load of parts, and I'd trade it ALL for that car! (Yes, I know you aren't interested in any trades.) It should go fast for the price you're asking. Good luck.
    Dallas
  20. kikgas01
    533
    0
    Oct 10, 2009
    Iowa
    Local Time:
    7:04 PM
    It still didn`t explode. I know they had 2 cars.
  21. Wylde1
    2,329
    8
    Sep 1, 2008
    Local Time:
    8:04 PM
    I'll be a monkey's uncle. You're right.
    fnabody, we'll need to recreate that scene and we'll feature your Charger. It might come back a little battle weary, but it'll be a star! :-D
    Wylde1.
    http://www.youtube.com/watch?v=Z-7IEPTAoTg
  22. OldVart
    OldVart Well-Known Member
    5,284
    9
    May 24, 2005
    Forestburg, Alberta, C eh n eh d eh
    Local Time:
    6:04 PM
    Beautifully done Charger. Good luck with your sale.
  23. Blownfish
    1,044
    7
    May 26, 2009
    St.Louis
    Local Time:
    7:04 PM
    Sorry! I never said it exploded, I said it was destroyed in that scene.
    I just found the MCG issue the car appeared in, it was in Feb. 09
  24. bamacuda
    2,159
    69
    Jan 2, 2007
    Hoover, Alabama
    Local Time:
    7:04 PM
    My question is, "Do you have enough hubcaps to be a true Bullitt tribute?" Seems like there were about 7 hubcaps rolling or still on the car. I'll watch it again and see if I can count. Also, I want a green VW bug. They are fast. I noticed that the Charger passed it three times, and it kept getting back in front. My '69 bug wasn't that fast, but I guess that's because it was baby blue!
  25. fnabody
    816
    70
    Aug 11, 2009
    Local Time:
    8:04 PM
    Wylde1,
    if you or anyone else buys the car feel free to scrape all the guard rails you want, loose all the hubcaps you want, run it into any camera guys you want, side swipe all the cars you want, and finish it off by flying into any gas pumps you want. I just don't have the heart to do any of those things. If the car gets a new owner I would not want to know if any of those things were being planned for this car. I know your comment was made in good humor, at least that's how I took it.:-D
Thread Status:
