1. danan
    danan Member
    7
    2
    Oct 29, 2008
    Local Time:
    5:36 PM
    I'm building a clone-ish 1968 SS barracuda. I scrounged up an original bellhousing (246-3236 casting number) but am unclear on which flywheel (diameter and teeth) and starter is used with it. Please advise. Thanks!
  2. danan
    danan Member
    7
    2
    Oct 29, 2008
    Local Time:
    5:36 PM
    Well a 1968 direct drive hemi starter doesn't fit the bellhousing but a standard gear reduction starter drops in perfectly. So that's one question out of the way. I suspect (hope?) that a 130 tooth 8 bolt flywheel is correct for these cars. Does anyone know for sure?
  3. ns1rm21
    ns1rm21 Well-Known Member
    544
    383
    Feb 22, 2008
    Local Time:
    7:36 PM
    I know what your doing and I respect it. I have a 68 Hemi Barracuda clone that I’m finishing up and it has a 4 speed.
    Originally in those cars they used 1967 B body factory scatter shields and they had TONS of problems with clutch forks, Z bars and pivot brackets working together. Do yourself a huge favor and just run stock 1968 A body 383 shifter components and clutch linkage. Then use 1970 130 tooth flywheel and 10.5 clutch setup and aluminum bell housing. I know it’s not 100% correct but you will thank me in the long run. A19FF071-270D-4C08-8C4D-7990D8DA3EEE.jpeg 8F7C068A-1540-4595-A986-E72F44747F92.jpeg AF69D545-90E8-4DA3-AEFA-F0CD5D57075E.jpeg 9D47263E-DF38-477F-A031-0A1EC8155E1C.jpeg
    • Like Like x 2
    • ns1rm21
      544
      383
      Feb 22, 2008
      Local Time:
      7:36 PM
      PS…..if you get a repop pivot bracket put it in a vice and give it a few light hits with a hammer before you install it. Mine broke while I was installing it and many other people had problems as well. See photo above.
    • davescuda
      davescuda FABO Gold Member FABO Gold Member
      11,126
      2213
      Apr 30, 2007
      Cheshire, CT
      Local Time:
      8:36 PM
      Pictures of the shifter set up if your looking to do the correct set up.
      • Like Like x 2
      • danan
        danan Member
        7
        2
        Oct 29, 2008
        Local Time:
        5:36 PM
        Thank you for the reply and insight (insight based on experience is the best kind).
        In Schild's book he claims that the factory used 64-65 Race Hemi bellhousings. Is this another instance where the book isn't accurate?
        I'm not sure how the early units differ from the later ones, besides the markings and part numbers. Ironically, I spent a lot of time and no small amount of money finding a complete 64-5 bellhousing and inspection cover, and all the while I had a 1970 aluminum bellhousing/clutch fork/etc sitting on the shelf.
        Did you modify the pivot bracket per the factory drawing in order to keep it parallel with the frame mounted pivot? I will certainly check for poor weld penetration prior to installation. I'm glad your bracket fell apart upon installation, vice hammering down the track!
        I'll probably give the 'correct' set-up a go, and if I can't make it work I won't hesitate to swap in the aluminum bellhousing. I really appreciate your help and recommendations. Would you mind if I PMed you from time to time as I build this thing?
      • autoxcuda
        autoxcuda Well-Known Member
        7,613
        1918
        Apr 6, 2007
        Local Time:
        5:36 PM
        Not bad for moving on its own power for very first time.
        • Like Like x 1
        • ns1rm21
          544
          383
          Feb 22, 2008
          Local Time:
          7:36 PM
          PM me anytime!
          My notes say “A990 bell housing”, I’m not sure what year those are. I thought that was the WO and RO 1967 cars but I might be wrong.
          The big problem is there B Body Bell housing and the Z bar does not have a straight shot between the bell and the frame pivot.
          Another problem is they used a B body Z bar (why I don’t know) and the upper arm that the pedal rod attached to is too long so the pressure plate would go beyond center. The fix was to drill out the stud that the upper link goes on and move it down 1”.
          I use the TTI headers, again not 100% accurate but they fit very well (TTI used my Dart for the mock up) TTI has a Z bar that fits perfectly and let me tell you with a 2 1/8” header things get REAL tight down there.
        • danan
          danan Member
          7
          2
          Oct 29, 2008
          Local Time:
          5:36 PM
          I have the TTI headers as well, but still need to order their modified Z bar. I received all the shifter linkage, handle, etc from Brewer's, but have yet to find a reverse lockout kit. That's been a tough one to locate!
          I was really fortunate to get a SS shifter bracket from Davescuda. It looks exactly like the pictures in Schild's book. Really nice piece. Thanks again!
          • Like Like x 1
          • tribe_of_dan
            tribe_of_dan Well-Known Member
            108
            33
            Aug 29, 2016
            Columbus, OH
            Local Time:
            8:36 PM
            I’ve not been on here in a while. Here is my steel bell-housing for what it’s worth.
            • Like Like x 1
            • ns1rm21
              544
              383
              Feb 22, 2008
              Local Time:
              7:36 PM
              Very, very nice!!
              Have you mocked up this combo in your car yet?
              Those bell housing are based on B body’s. This means that your Z bar will not line up between your B body bell housing and you A body car. E61A86C7-FE36-43DF-9E1E-A2BD27B4CEEE.jpeg B9BABD0D-3C89-4E70-BD56-5BEDBD22C9D5.jpeg 1CC94DE5-3B7D-4FE9-A56B-CFCDC043870B.jpeg
              • Like Like x 1
              • tribe_of_dan
                108
                33
                Aug 29, 2016
                Columbus, OH
                Local Time:
                8:36 PM
                Not yet. I bought the modified TTI Z-bar. What are these notes that you have? Originals?
              • ns1rm21
                544
                383
                Feb 22, 2008
                Local Time:
                7:36 PM
                …sorry, one more thing. That bell housing comes real close to the pinch weld between fire wall and floor pan. Keep an eye on it when installing your trans cross member.
                Keep us all posted, looks real good!
                • Like Like x 2
                • tribe_of_dan
                  108
                  33
                  Aug 29, 2016
                  Columbus, OH
                  Local Time:
                  8:36 PM
                  Will do. The car is out of my hands not and at a shop. I’m sure we’ll be going back and forth a little esp. if there are any fitment issues.
                • ns1rm21
                  544
                  383
                  Feb 22, 2008
                  Local Time:
                  7:36 PM
                  This are original notes from Bob Tarozzi when he was designing and building these cars. Here is Bob in my car at Spring Fling a few years back 2BF393FC-CC22-475E-9613-286A3FC77925.jpeg
                  • Like Like x 2
                  • tribe_of_dan
                    108
                    33
                    Aug 29, 2016
                    Columbus, OH
                    Local Time:
                    8:36 PM
                    That is fantastic. If we run into any issues I’ll be sure to reach out. I’m not going for 100% perfect as far isn’t original but it’s going to be a fair bit closer than many I would say.
                    • Like Like x 1
                    • RustyRatRod
                      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                      81,244
                      60753
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      8:36 PM
                      What an awesome spectacle!
                      • Like Like x 1
                      • ns1rm21
                        544
                        383
                        Feb 22, 2008
                        Local Time:
                        7:36 PM
                        Very good, anything I can do or if you have any question maybe I can help. Here is a picture of my two clones. Dart is auto with 8 3/4 and the Barracuda is a 4 speed and a Dana so I got things covered. 37E42219-E99C-4ED1-A12F-BF4C5FFDA1F1.jpeg
                        • Like Like x 1
                        • Thanks! Thanks! x 1
                        • tribe_of_dan
                          108
                          33
                          Aug 29, 2016
                          Columbus, OH
                          Local Time:
                          8:36 PM
                          This is amazing!
                          • Like Like x 1
                          • danan
                            danan Member
                            7
                            2
                            Oct 29, 2008
                            Local Time:
                            5:36 PM
                            Tribe of Dan: I believe I have the same bellhousing/inspection cover as you. What flywheel are you using? It appears that a std 10.5" 130 tooth flywheel fits our bell housings. Is this correct?
                            Troy: thanks for the pictures of the mounting bracket drawings; those are very helpful because Schild's guide does not have the corrected ball stud height (book shows 3.04" from centerline of the mounting hole to centerline of the ball stud). Your drawing appears to have the 3.04" dimension lined out and 3.17" written below it.
                            Also: what a magnificent pair of cars! I love the license plates.
                            • Like Like x 1
                            • tribe_of_dan
                              108
                              33
                              Aug 29, 2016
                              Columbus, OH
                              Local Time:
                              8:36 PM
                              I believe 130 is correct but I can’t prove it. I have the 130 based on Brewers advice.
                            • ns1rm21
                              544
                              383
                              Feb 22, 2008
                              Local Time:
                              7:36 PM
                              You should be able to look through the whole were the starter goes to see if the starter would engage. You could even install the starter and jump it and see if the starter engages.
                            • HemiSSDart
                              HemiSSDart Dartus Interuptus
                              2,023
                              1591
                              Feb 20, 2013
                              Illinoisy
                              Local Time:
                              8:36 PM
                              Yes, 10-1/2" 8-bolt flywheel and regular starter or mini starter work just fine on the STEEL bellhousing. I am still looking for a STEEL inspection cover for my bellhousing. I am also still looking for the correct HD Hurst linkage, got everything else. My car was originally a 4-speed, but getting it going with an automatic first...
                            • danan
                              danan Member
                              7
                              2
                              Oct 29, 2008
                              Local Time:
                              5:36 PM
                              Did Hurst sell the HD linkage over the counter? Do you have a picture of it?
                              I just have stock A-body shift rods and tabs.
                            • HemiSSDart
                              2,023
                              1591
                              Feb 20, 2013
                              Illinoisy
                              Local Time:
                              8:36 PM
                              They are on the trans picture above on post #5...
                              • Agree Agree x 1
