[FOR SALE] 1969 340 Radiator 2949066 38086
OnEbAd340
RI
Rating - 0%
0   0   0
Came out of my car, going to an aluminum radiator and would rather see this go to someone's restoration than sit under my work bench.
Was serviced/ repaired back in the early 90s and never saw the street besides the occasional start up in the garage. When I pulled it from the car before sending it to the body shop it didnt leak. From moving it around,it has a few bent over fins.
Asking $150 located in RI & CT
Driver side upper and lower hose. Did you cap the trans cooler or did this come out of a stick car?
It does have two plugs at the bottom, unsure to be 100% honest what they are for. Probably for an automatic,maybe someone can chime in?One is located 3 inches from outlet and the other is 1.5 inches from drain petcock. My car is originally a 4 speed car, but maybe it was swapped in at some point.
Part # Year Body Size Engines Trans HVAC Notes
2949066 1969 A 22" 340 Both Heater
