[SOLD] 1969 Barracuda Convertible
pacuda59
pacuda59
Pennsylvania
Six Cylinder/Automatic
123,000 miles?
  • Upgraded brakes to front disc/rear drums, big bolt pattern
  • Cragar SS wheels
  • Upgraded rear end from 7.25 to 8.25
  • New master cylinder and brake pump
  • New steering box and pump
  • New bushings
I've purchased over $2,000 worth of parts that I haven't installed. Including......
  • Super Six (intake & exhaust manifolds, two barrel carb, complete linkage.
  • Electronic ignition from '76 Volare.
  • Center console as well as mounting brackets and shifter (currently on steering column).
  • Visors & headrests.
  • New windshield washer reservoir and floor pump.
  • Under dash speaker mounts for dual speaker setup.
  • New carpet
  • Dash gauges & bezel
  • Sway bar
  • Trunk opener electronics
  • Thumbwheel AM radio
  • Big bolt pattern spare wheel
  • Firewall gaskets
  • Windshield wiper stem gaskets
  • Interior & exterior trim
  • New heater core
  • More.....
The car drives nicely and looks good from the outside. There is a small tear in the top as well as a few paint chips. The floors are great and will need a new interior as the upholstery is original. There is a small leak in the heater core and I've looped the heater hose to bypass. If I get the time, I'll replace.
Car is located in eastern PA, in the Lehigh Valley.
$17,000
