[FOR SALE] 1969 Dart GTS 440 M-Code
Dave Stevens
Member
Syracuse NY
Rating - 0%
0   0   0
For Sale $55,000
1969 Dodge Dart GTS
Factory M-Code 440 RB Big Block Car
54,000 original miles
640 of these M-Code 440 GTS cars
We’re produced in 1969 only as
Special order Drag/Track/Strip purpose built
Asphalt slayers
3,000 lb car with 375 HP 480 ft lbs built in 1969 ?
That Was unheard of 50 years ago
Today only 49 M-Code 440 GTS cars
Are documented and accounted for as surviving
Vehicle was restored 14 years ago
And has roughly 800 miles driven since documented resto
440 bored to 452
Mild Camshaft
Correct 906 heads with larger valves-stainless
Edelbrock/Carter AVS 750 carb
Engine fully rebuilt
New pistons,rings,bearings etc
Factory exhaust manifolds
Accurate exhaust system from manifolds to tail pipes
727 automatic Torqueflight fully rebuilt
New B&M 2,800 rpm converter
8-3/4 rearend with 742 center & 3.23 gears
Fully rebuilt ,green axle bearings
New Seat covers ,Headliner , carpet during resto
All original sheet metal
Except pass side rear quarter skin was replaced
Have folders and photo book
Of all receipts and documented restoration
14 year old restoration is showing its age slightly
But shows very well still
Originally sold here in my hometown
Syracuse NY by Sam Dell Dodge
Car was a sponsored track car for many years
Sponsored by Sam Dell Dodge
Then retired and put into storage for many years
Sold and later restored from 2002-2004
800 miles since documented resto
$55,000 Firm
price? point I have other than all I nearly died. sold non ins parts to mancini. manifolds ar they 4 sale. mine broke both sides.have 383 gts and manifolds . r diff tried and bought 2 put on 383 to 440 car. 440 r 2 PLS inches taller destroyed 2 383 gts trying 2 bulid.
Are you asking if I’d sell
The extremely rare hard to find original 440 RB A-Body factory exhaust manifolds from my car ????
The last time that I had seen the car it had a 383 A-Body manifold on it so can you please confirm that the casting number of the drivers side manifold is a 3462017. Thanks
@charles mill
I’m still not sure what your trying to ask
Or the statement your trying to relay
