[WANTED] 1969 Dart rear fender side marker bezels
ocdart
Inland Mopars Car Club
North OC, SoCal
My painter seems to think the front fender and rear fender side marker bezels are different, but the internet repop offerings seem to be the same for both. Internet info also says they're the same for both A-bodies and B-bodies.
Are the the same or different?
Anyway, the two for the rear of my '69 Dart have gone missing somewhere in the various paint shops it's been in.
Please show pics and price of what you've got.
THANKS!
THANKS!
I have one. Can be viewed on pg.7 in exterior parts.
THANKS!
Most of the 1969 side marker housings are different due to the shape and angle of the quarter panel. Most will swap around, but, the angle and depth of the lens will be off. There is also an early and late lens that year. Up to Jan 1st 1969 is one lens, and after that date is another. They interchange, but, there's a slight appearance difference.
Most of the 1969 side marker housings are different due to the shape and angle of the quarter panel. Most will swap around, but, the angle and depth of the lens will be off. There is also an early and late lens that year. Up to Jan 1st 1968 is one lens, and after that date is another. They interchange, but, there's a slight appearance difference.
The one I have for sale came from a 69 Dart at a local pick-n-pull. It was from left side, but I believe they are interchangeable.
The fronts are different, because they have studs that hold the retainers on with nuts. I don't know the build date on that car.
It's long gone.
It's long gone.
Yes, left and right are the same. I think the lenses have a different number between the early and late. One has 69C cast into it. I can't remember what the other one has. There's probably a part number on it there somewhere to match also.
I have two bezels from my 69 dart. They are held in with two screws and lens snaps in. I can text pics with a phone number if you want. and my bezels are the same front and rear if it helps.
69 Dart uses it's own rear side marker housing and uses the same lens for 69 Station wagons. It will not accept a lens like a b-body car due to the clips being moved inward. It should have(If I remember) a 69PS on lens...
